Finding distance using vector components
6 replies · 4K views
LadyTwi
With reference to Fig. 3 (not accurate), where the origin is at the centre of the image, if r1 = (0.10)î+(-0.80)j hat, and r2 = (-0.90)î+(0.10)j hat, what is the distance between the dots?
Unsure.
I'm not so good with these i hat and j hat vector components. I've tried using (x2-x1) + (y2-y1) but that didn't give the correct answer. I'm not really sure what I can do with the two equations.
here's some reading for you to do that should help!
http://www.physics.uoguelph.ca/tutorials/vectors/vectors.html
That is a helpful link, however I still can't get the answer. XD Do I have to find the angle between r1 and r2 and use that to find the distance or does it have to do with the addition of the i hat components and the j hat components?
the beauty of unit vectors is that it already takes the angle into consideration! all you have to do in this case is add the i vectors with i vectors and js with js.
I've tried that but BLS/CAPA is still telling me that my answer is wrong. Maybe I'm entering it wrong...?
The distance between two points is the magnitude of the vector connecting these two points. In your problem this vector is [tex]\vec{r} = \vec{r_{2}}-\vec{r_{1}}[/tex]. To encounter the magnitude of this vector, all we have to do is calcute the scalar product of it with itself and take the square root. So,
[tex]distance = \sqrt{\vec{r}\dot\vec{r}}[/tex].
Thank you! I have the answer now. =D
