Finding Domain of f(x) & g(x) Equations
  • Thread starter Thread starter xnonamex0206
    Domain
The discussion revolves around determining the domain of various functions derived from f(x) = 2x - 5 and g(x) = 4, specifically focusing on the operations (f+g)(x), (f-g)(x), (fg)(x), and (f/g)(x).
  • Participants explore the concept of domain, questioning whether the domain includes all real numbers and under what conditions certain functions may not yield real numbers. There is a focus on the implications of division by zero in the context of (f/g)(x).
Some participants have provided insights regarding the definition of the functions and the conditions under which they are valid. There is ongoing exploration of the largest possible domain and the intersections of the domains of f and g.
Participants note that the functions must be defined for all elements of their domains, and there is a specific emphasis on the need to consider where g(x) does not equal zero for the function (f/g)(x).
xnonamex0206
Find a. (f+g)(x) b. (f-g)(x) c. (fg)(x) d. (f/g)(x)
f(x)=2x-5 & g(x)=4
(f+g)(x)=2x-1
(f-g)(x)=2x-9
(fg)(x)=8x-20
(f/g)(x)=2x-5/4
When I've completed all the other equations, I'm stuck on domain. I'm thinking that its all reals, but I'm not quite sure on how this is true. Is it because it cannot equal zero, or a non-negative number?
In other other words how exactly do you find the domain?
Just a little note, they are actually asking for the *largest* possible domain of each function over the reals, as you can give a function any domain you want, as long as the function is defined for every element of its domain.
Is there any value of x for which any of your functions does not yield a real number? If they exist, these x's cannot be in any domain of your function.
Hint: The identity function I(x) = x is defined for all real numbers x. Your functions are just real numbers added to real multiples of this function. Ie., it boils down to showing that if x is a real number, then kx is also a real number for real k.
PS. Your (f/g)(x) is missing the division by 4.
fg, f+g and f-g are defined everywhere, where f and g are both defined. f/g is defined everywhere, where f and g are both defined and g does not equal zero.
What does the k represent? So if x is a real number then the domain should include all reals? So basically to find the domain you should plug in some x's to see if they aren't real numbers?
I fixed the (f/g) forgot to add the /4.
What!?
Yes, xnoname0206 is correct. If the domains of f and g are not the same, the domains of fg, f+ g and f-g are the intersections of the domains of f and g. That is what xnoname0206 meant by "where f and g are both defined". f/g is defined on the intersection of the domains minus points where g(x)= 0.
  • · Replies 23 ·
