Finding e^AT for a 3×3 matrix with triple eigenvalue
  • Thread starter Thread starter bengaltiger14
    Exponential Matrix
13 replies · 10K views · last reply
bengaltiger14
Given the matrix: A=[-2 0 0;4 -2 0;1 0 -2], find e^AT.
I found the eigenvalues to be -2,-2,-2.
How do I solve this problem with 3 identical eigenvalues? Do I cube to matrix after plugging in my eigenvalue -2 and then solve it that way?
After plugging in the eigenvalue -2, the resulting matrix is: [0 0 0;4 0 0;1 0 0]
I could eliminate the 1 from row 3,col 1 and end up with two free variables. I am unsure after this.
If you can split the matrix A=B+C in such a way that B and C commute (i.e. BC=CB) then you can use e^A=e^B*e^C. Can you figure out how to do this in such a way that e^B and e^C are easy to compute?
splitting the original matrix or the matrix with the -2 eigenvalue?
The original matrix. If you can split it into easy commuting parts, you don't need the eigenvectors.
I think my prof. wants us to use the Eigenvectors, but i do not know how to split it the way you are talking of.
Do it the easy way first. Split it into a diagonal part and an off-diagonal part. Do they commute? The off-diagonal part is nilpotent, it's easy to find both exponentials.
I am not sure how to split as you are talking. But the diagonal would just be a diagonal of e^-2t? And everything else just 0?
Yes, the exponential of the diagonal part (call it B) is the diagonal matrix with entries e^(-2). 'Everything else' is the matrix C=[0,0,0;4,0,0;-2,0,0]. e^C isn't 0. What is it? Notice that C^2=0 and put it into the series definition of the matrix exponential.
bengaltiger14 said:
e^C would be: C=[0,0,0;e^4t,0,0;e^-2t,0,0]
Not at ALL. e^C=I+C+C^2/2!+C^3/3!+... Isn't it? And don't forget before you can say e^(B+C)=e^B*e^C you HAVE to show B and C commute.
So, the resulting matrix would be: [e^-2t,0,0;4e^-2t,e^-2t,0;e^-2t,0,e^-2t]
Does this look right?
No, not yet. Concentrate on e^(Ct) first. It's I+Ct+(Ct)^2/2!+... What is that? I just noticed that t floating around. You'll have to add it to some of my previous posts.
That is: [1,0,0;4t,1,0;1t,0,1]
The e^C*eB = [e^-2t,0,0;4te^-2t,e^-2t,0;te^-2t,0,e^-2t]
That looks much better. You did check B and C commute, right? It's necessary.
