Finding eigenvectors for complex eigenvalues
3 replies · 3K views · last reply
alsvt
Conjugate of a complex number
Matrix reduction
My attempt is bordered. Sorry about the quality.
So I'm not sure what I'm missing. I use the exact same method that I use for normal eigenvectors, just with complex numbers in the mix.
You messed up in the last step and swapped x1 and x2. If you let x2=1, then your equation gave you x1=-1/2+1/2 i. In the vector, however, you have the two values in the other order.
I can't quite read all of your work, but if you subtract [tex]\lambda[/tex] along the diagonal, you get:
[tex]\bmatrix<br /> 1 + i & 1 \\<br /> -2 & -1 + i \\<br /> \endbmatrix x = 0[/tex]
The rows of this matrix are multiples (-1 + i) of each other, so you can use either row to find the eigenvector:
[tex]x_1 (1 + i) + x_2 = 0[/tex]
[tex]-x_1 (1 + i) = x_2[/tex]
so your vector is (1, -1 - i). This happens to not be one of your choices, but you can multiply it by i to obtain (i, 1 - i).
@vela Thanks. I wasn't really thinking it through at the end.
