Finding Focus Points of Parabolas in Conic Sections
8 replies · 3K views · last reply
skybox
Hi all,
I am having an issue with the following problem. I just don't know how to approach it.
Text problem asking for the x and y coordinates of the focus of a conic section given by r sin^2 a = cos a, with a note that angle a corresponds to a right triangle with adjacent side x, opposite side y and hypotenuse r.
Ax^2 + Bxy + Cy2 + Dx + Ey + F = 0
Handwritten equations: r = cos(alpha) / sin^2(alpha), and below it x^2 + y^2 = r^2.
Equation x^2 + y^2 = cos^2 α / sin^4 α, with the right-hand side written as a fraction.
I am confused on how to put this problem in terms of x & y and get numerical values for both x & y. Any guidance would be greatly appreciated :)
skybox said:
Hi all,
Text problem: What are the x and y coordinates of the focus of the conic section described by r sin^2 α = cos α. Angle α corresponds to a right triangle with adjacent side x, opposite side y and hypotenuse r.
Equations: r = cos α / sin² α, and x² + y² = r² (the first character of the second line is partly obscured).
Handwritten equation x^2 + y^2 = cos^2 α / sin^4 α, with the right side written as a fraction.
Try putting ##\sin\alpha = y/r## and ##\cos\alpha = x/r## in your equation.
Great thank you. That was a big help and is starting to make sense now. Since it is a right triangle, your equations can be used.
[tex]x^{2}+y^{2} = \frac{(\frac{x}{r})}{(\frac{y}{r})^{2}}[/tex]
[tex]\therefore x^{2}+y^{2} = \frac{(\frac{x}{r})}{(\frac{y}{r})^{2}}[/tex]
[tex]\therefore x^{2}+y^{2} = (\frac{x}{r}) * \frac{y^{2}}{r^{2}}[/tex]
[tex]\therefore x^{2}+y^{2} = (\frac{x}{r}) * \frac{r^{2}}{y^{2}}[/tex]
[tex]\therefore x^{2}+y^{2} = ({x}) * \frac{r}{y^{2}}[/tex]
I am still a little confused on how to get numerical values for x & y. This looks like it can be solved via the unit-circle if I set the right hand side of the equation to 1. Does this look right?
Thanks~
That third step is wrong. To divide fractions you "invert and multiply". Also put in ##r^2## on the left side after you fix the right side.
Also, I missed that you had put ##x^2+y^2## on the left. That is ##r^2##. Your original equation just has ##r## and you should leave it there.
Yes that was a typo. I actually do the correct method in step 4.
I am getting the following:
[tex]r = \frac{x}{r} * \frac{r^{2}}{x^{2}}[/tex]
[tex]cos \alpha = \frac{x}{r}/[tex] [tex]sin \alpha = \frac{y}{r}[/tex]<br /> [tex]r = \frac{\frac{x}{r}}{\frac{x^{2}}{r^{2}}}[/tex]<br /> [tex]r = \frac{x}{r} * \frac{r^{2}}{x^{2}}[/tex]<br /> [tex]r = \frac{x}{r} * \frac{r^{2}}{x^{2}}[/tex]<br /> [tex]r = \frac{xr}{y^{2}}[/tex]<br /> [tex]r = \frac{xr}{y^{2}}[/tex]<br /> [tex]1 = \frac{x}{y^{2}}[/tex]<br /> <br /> Stuck again...now a little confused. Do I need to put this in the form [tex]x^{2} + y^{2} = r^{2}[/tex][/tex][/tex]
You want an x-y equation. What's wrong with ##x=y^2##? Now use what you know about xy conics to locate its focus.
Great. I think I got it. Since this equation is in the form of:
[tex]x=y^{2}[/tex]
it is a parabola with the general equation of [tex]x = a(y-k)^{2} + h[/tex]. a = 1 and k = 0 in this case. The focus point for a parabola in this form is at [tex](h+p, k)[/tex] And [tex]p = \frac{1}{4a}[/tex]. Therefore, since a = 1, [tex]p=\frac{1}{4}[/tex].
The focus point is therefore [tex](\frac{1}{4}, 0)[/tex]
Thanks LCKurtz!
