What focal length is needed for a 0.60x magnification with a diverging lens?
  • Thread starter Thread starter Taylor Marks
    focus
To achieve a magnification of 0.60x with a diverging lens for an object 1.40 meters away, the formula M = -di/do is applied, resulting in di being -0.84 meters. The lens formula 1/do + 1/di = 1/f is then used, leading to the calculation of the focal length f. The final calculation indicates that the required focal length is approximately 1.42 meters. There is a clarification regarding the sign convention in the calculations. The discussion emphasizes the importance of correctly interpreting the signs in lens equations.
Taylor Marks
What focus is needed for in order for a diverging lens to produce a magnification of 0.60x on an object located 1.40 meters away?
M=hi/ho
1/do + 1/di = 1/f
M= -di/do
-di / 1.4 = 0.6
1/1.4 + 1/.84 =1/f
-di=0.84
1.42
M=hi/ho
1/do + 1/di = 1/f
M= -di/do
-di / 1.4 = 0.6
1/1.4 + 1/.84 =1/f
-di=0.84
1.42
Is that + sign correct?
Just a small remark - rather say what focal length is needed...
9K
