Finding Frequency of an Oscillating Disc with a Hole
The discussion centers on calculating the oscillation frequency of a circular disk with a rectangular hole, specifically when the pivot point is at the center of mass. The disk has a radius of 0.600 m, a mass of 0.390 kg, and a moment of inertia of I_p = 2.60E-1 kgm². The period of oscillation was calculated using the formula T = 2(pi)√(I/mgd), yielding a result of 1.93 seconds. However, it was concluded that if the pivot point is at the center of mass, the frequency of oscillation is zero, as there is no torque acting on the disk.
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with the formula for the period of oscillation T = 2(pi)√(I/mgd)
  • Knowledge of the concept of center of mass in physical systems
  • Basic principles of torque and its effect on rotational motion
  • Study the implications of pivot points on oscillation in rigid body dynamics
  • Explore advanced concepts in rotational motion, including torque and angular momentum
  • Learn about the effects of different shapes on moment of inertia calculations
  • Investigate pendulum motion and its variations in different configurations
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in understanding the dynamics of oscillating systems.
Becca93
A circular disk with a rectangular hole has a radius of 0.600 m and mass of 0.390 kg. It is suspended by a point on its perimeter as shown in the figure. The moment of inertia about this point is I_p = 2.60E-1 kgm2. Its center of mass is located at a distance of s=0.120 m from the center of the circle as shown. [Photo attached]
What is the oscillation frequency if the pivot point is at the center of mass?
The attempt at a solution
In truth, there were two parts to this question. The first, I had to find the periodof oscillations if it was allowed to oscillate side to side as a pendulum.
I used the equation T = 2(pi)√(I/mgd) and found that the answer was 1.93 s.
However, I'm at a loss as to how to try to solve for the frequency with the pivot point at the center of mass. Obviously, taking the inverse of the above answer resulted in an incorrect answer.
Any and all assistance would be hugely appreciated.
The problem as stated doesn't make sense to me. If the pivot point is through the center of mass, it won't oscillate because there will be no torque on the disc regardless of its orientation.
I realized that not long after I asked. I'm now assuming it's a trick question. 0 is the correct answer. I think it was trying to show that because distance from the center of mass was zero, all the rest was zero as well.
