Finding gain factor when multiplying signal by constant in dB
7 replies · 2K views · last reply
asdf12312
Homework problem text: part (b) x(t) = e^{-t}u(t) + e^{-t}[e^{2t-4} - 1]u(t-2) - e^{t-4}u(t-4), followed by part 8 asking to apply a 5 dB gain so the new signal's energy is 4 dB higher, with a plotting instruction.
The ratio of the parameters [itex]\frac{E_1}{E_2}[/itex] to find the gain (in dB), 10[itex]\times[/itex]log10[itex]\frac{E_1}{E_2}[/itex].
"To determine the gain factor in part 8, first think about what happens to the energy when you multiply the signal by a constant factor. Then use the logarithmic formula above to solve for the gain factor."
Since energy is square of integral of a f(x), I am thinking if f(x) is multiplied by constant factor then energy will be square of that factor greater. I already have E1 of the problem, which is the energy of f(x) above = 2.99. I am confused I think because problem says 5dB then 4dB. anyway..if I assume gain of energy is equal to 4dB i have:
4dB = 10[itex]\times[/itex]log10[itex]\frac{E_1}{E_2}[/itex]
0.4 = log10[itex]\frac{E_1}{E_2}[/itex]
[itex]\frac{E_1}{E_2}[/itex] = 2.512 → E2 = [itex]\frac{2.99}{2.512}[/itex] = 1.19
but why is the energy less than the original though? am i doing this right so far??
asdf12312 said:
Typeset homework text: part (b) defines x(t) = e^(-t)u(t) + e^(-t)[e^(2t-4) - 1]u(t - 2) - e^(t-4)u(t - 4); problem 8 asks to apply a 5 dB gain to the signal from part 2.b.
Why do you say it is less? The ratio of 2.512 is correct.
I got confused cause the new energy is less then the one I calculated (2.99). So a gain of 4dB in the energy results in E2=1.19. How would I find the constant factor that I need to multiply the signal by? I am guessing it is something like A*x(t) and I have to find A that results in this new energy value.
I don't understand the 4dB vs. 5 dB discrepancy, either. Must be a typo.
You are confusing ##E_1## and ##E_2##. :frown: Once you sort that out you'll be right.
OK that's what I thought. So they would be reversed, right? In that case I get E2=7.51. So then A2=2.74. The ratio [itex]\frac{A_2}{A_1}[/itex] = 1.585. So this would be the constant factor I multiply x(t) by. Is this right?
"The text for part 8 refers to both a 5 dB and a 4 dB gain. This is a typo. The gain to be applied is 5 dB. This has been corrected in the PDF.."
Our instructor just send out that message lol. so I guess it was a typo..
That gives you the opportunity to redo the problem, this time using 5dB. :smile:
