Finding homogeneous solution for x²y" - 3xy' + 4y = x⁴
xtipd
Ok here's my problem:
1. Solve the inhomogeneous second order de:
x^2y" - 3xy' + 4y =x^4
2. Worked: y(p) = 1/4*x^4
Given: y(1) = x^2
y(2) = log(x)*x^2
3. I just need help getting the roots of the given de so i can determine y(h) of this de. As i have already solved the particular solution y(p) and then the general solution
y(g) = y(h) + y(p)
Im thinking this has imaginary roots as i gave it a crack to get y(h) and the best i could think of was (r - 2/x) - 1/x = 0, which doesn't really lead me anywhere i think.
Do i have to use the quadratic formula to get the roots of this equation? and if so some pointers in the right direction would be much appreciated!
Thanks
solve x^2y" - 3xy' + 4y=0 to get two solutions,y1(x) and y2(x), for the variations of parameters method.
Given: y(1) = x^2
y(2) = log(x)*x^2
y(g) = y(h) + y(p)
? You are given that two independent solutions to the associated homogeneous equation are x^2 and log(x)x^2.
You don't need to do that at all, you are given those solutions!
Of course, the general solution to the entire equation is y(x)= Ax^2+ Blog(x)x^2+ (1/4)x^4 but I suspect you got that yp by "undetermined coefficients" so have not followed the instructions to use "variation of parameters".
Thanks
Although, as I said, you do not need to solve the characteristic equation, no it does not have imaginary roots. You can convert a "Euler type" or "equipotential equation" to a "constant coefficients" equation with the change of variables t= log(x) or x= e^t.
dy/dx= dy/dt dt/dx= (1/x)dy/dt so d^2y/dx^2= d ((1/x)dy/dt)/dx= (1/x) d(dy/dt)/dx- 1/x^2 dy/dx= (1/x)^2 d^2y/dt^2- (1/x^2)dy/dt so x^2d^2y/dt^2- 3x dy/dx+ 4y= x^2(1/x^2)(d^2y/dt^2- dy/dt)- 3x (1/x)dy/dt+ 4y= d^2y/dt^2- 4 dy/dt+ 4y= 0. The characteristic equation for that constant coefficients equation, and so for the equipotential equation, is r^2- 4r+ 4= (r- 2)^2= 0 which has r= 2 as a double root. For a constant coefficients equation, that would mean the solution was y= Ae^(2t)+ Bte^(2t). Since t= log(x), e^(2t)= e^(2log(x))= e^(log(x^2))= x^2 and te^(2t)= log(x)x^2, as "given".
We were given the solution y(1) = x^2 was a solution, then had to prove y(2) = log(x)x^2 is also a solution.
Haha your spot on about me getting y(p) via constant coefficients, which i ended up realising just before and ajusted my solution. Seems so stupid now i look back at it.
I did end up using the change of variables with x= e^t and also got the root r(1)= r(2) = 2 so y= Ae^(2t)+ Bte^(2t) just like you mentioned, and went on to get the general solution.
All cleared up now, help was much appreciated!
