Finding image position from concave mirror with 1.4 m radius
2 replies · 4K views · last reply
Aneadra
A concave mirror with a radius of curvature
of 1.4 m is illuminated by a candle located on
the symmetry axis 3.4 m from the mirror.
Where is the image of the candle? Answer
in units of m.
I tried plugging in the numbers into the di=do equation but i think that's wrong out of this world.lol
Why do you feel the need to plug numbers into an equation? Why not do a ray tracing diagram and find out where the image is formed?
A ray from the bottom of the candle, situated on the axis of symmetry will be reflected back along that axis.
Then consider ray from the top of the candle parallel to the axis. Where will that ray be reflected?
Then consider a ray from the top of the candle passing through the focal point of the mirror. Where will that ray be reflected?
When you've done all that you'll know where the image is formed.Then measure off the answer from the drawing.
Using an equation should work, and is in fact how many physics problems are solved. But you do need to use the correct equation.
do=di is wrong, since they are not necessarily equal to each other. Can you not find the correct equation in your notes or textbook? If not, look here:
https://www.physicsforums.com/library.php?do=view_item&itemid=148
A curved mirror acts like a lens, but you need to be careful about what you use for f.
