Finding impedance that is unit step function
6 replies · 2K views
anol1258
Consider the following circuit which uses ideal components. Prior to t=0 switch S is open. Then suddenly at t=0 switch S is closed. Find the impedance [itex]Z_{2}[/itex] such that the system output is a unit step function of voltage. Be certain to show all components used to construct [itex]Z_{2}[/itex] and their connections along with component values of your design.
Z1 is Given
circuit:
KVL, KCL, V=IR,
Nothing yet. Just wanted to get this up here for now.
The output will not be a UNIT step function unless the input voltage is > 1V.
The solution furthermore is not unique. You can say pick any R2, then X2 is defined as is the voltage gain < 1.
Where Z1 = R1 + jX1 and Z2 = R2 + jX2.
Ok I understand why the input voltage has to be > 1V. So how should I start this out? Can I connect the two grounds and do a loop equation?
The two grounds are already connected, by definition.
Let Z1 = R1 + jX1, Z2 = R2 + jX2, then you have a voltage divider Vout/Vin = Z1/(Z1 + Z2). In terms of the real vs. the imaginary components of that transfer function, what has to be true to make the transfer function independent of frequency?
real and imaginary must be equal?
or reactance is 0?
anol1258 said:
or reactance is 0?
Much better! Come up with a Z2 such that the transfer function Z1/(Z1 + Z2) has no frequency sensitivity.
