Finding indicator for acid-base titration
  • Context: Chemistry
  • Thread starter Thread starter haha0p1
    Titration
7 replies · 3K views
haha0p1
Suggest a suitable indicator to find the end-points of the reaction below:
0.0500 mol/dm³ nitric acid and 0.0500 mol/dm³ aqueous ammonia.
Acid + Base = Salt + Water
This question is asking about finding the indicator. I think phenolphthalein will be used as there is a reaction between strong acid and strong base. Is this approach to the question correct? Or am I missing any important concept? Kindly tell
Ammonia solution is not a strong base...
What is the pH of ammonia, nitric acid and ammonium nitrate (the end product)
Check the pH that phenolphthalien changes colour at.
What colour will it show in the ammonia solution?
What colour will it show at the end point of the titration?
Reply
Ammonia is a weak base and nitric acid is a strong acid. Will methyl red be used?
Reply
That would depend on the pH around the equivalence point.
This is a two mark question. Can you tell how we will approach questions like this one.
So this is a homework question. How do you like this idea: Try to perform a titration of a strong acid with ammonia solution. Monitor the entire titration with a pH meter. Find the inflection point pH. Making a graph might be needed. Now find a table of pH indicators and choose an indicator which has a color transition as near to the pH inflection point found, as you can find.
haha0p1 said:
Homework Statement:: Suggest a suitable indicator to find the end-points of the reaction below:
Relevant Equations:: Acid + Base = Salt + Water
I could use some correction in case my thinking is wrong, but I would tend to agree here, to use phenolphthalein. Color change is at pH above 7 (but I not sure; I should really look-up this information). Full neutralization of ammonia would be at something above pH 7.
