Finding Initial Velocity: Projectile Motion Problem
brandon26
A particle is projected on a horizontal ground and moves freely under gravity.
The horizontal and vertical components of the initial velocity are 2u and u ms^1 respectively.
The ball lands a distance 80m from the point of projection.
Show that u=14
This is what I did:
Taking motion in the horizontal plane------
2u = 80/t
Taking motion in the vertical plane-----
displacement (s) =0
acceleration (a)= -9.8
initial velocity (u) = u
time of motion (t) = t
therefore using s=ut +(1/2)at^2
I get: 4.9t=u
substituting this into the first equation should give me the correct value of u, but it doesnt. Can someone tell me where i went wrong?
:confused: :confused:
[tex]0 = ut - 4.9t^2[/tex]
Assuming that t is non-zero, since that is an obvious solution, [tex]t = \frac{2u}{g}[/tex], therefore, since velocity in the horzontial plane is constant, [tex]4u^2 = 80g[/tex], then solve that
Why doesn't it? If u= 4.9 t, then t= u/4.9. Putting that into
2u= 80/t, 2u= (80)(4.9)/u so u2= 40(4.9). What do you think that is?
