Finding K when the limits of integration don't match
  • Thread starter Thread starter keewansadeq
    Calculus Theorem
23 replies · 3K views
keewansadeq
Can anybody give me hint how to find K if F(x)= 3x+2
The integral lower part is not the same, , how to deal with his?
Please ,I need hint to start
... or, why not just integrate what you've been given?
What is preventing you from just computing ##\int_2^x (3t + 2) \, dt## and ##\int_8^x (3t + 2) \, dt##?
Thank you all,
The point guys is that , first integration is start from 2 and the other one is start from 8.
Hence if I have only the base 2, the answer will be 3x+2 =3x+2(but the problem is the second base is 8), can't figure out what I missing till now?
How can I equate them?
Thanks again
That's not a valid answer for that definite integral.
Thanks
Could you upload refer to examples with X is the boundary of indefinite integral not numbers?
When a math problem proves to be too difficult, it is a good idea to work on it in little pieces.
Why don't you do as has been suggested above: forget about the exercise itself, and just compute the following integral:
##\int_2^x (3t + 2) dt##.
What result do you get?
What, exactly, is your difficulty? Have you been able to find an anti-derivative for 3t+ 2? That is, can you find [itex]\int 3t+ 2 dt[/itex]? What do you get when you substitute the upper and lower bounds and subtract?
The answer is 3x+2 (right)!
No.
Let's go one more step back (as suggested by HallsofIvy): what is the indefinite integral ##\int (3t +2) dt ##?
Sorry, a stupid question but ##F(x)=3x+2## is a primitive of ##f## or it is the ##f## in the integral?
That's not a stupid question, it's a good catch. :oldsmile:
Ah ok because in one case one must apply directly the Fundamental calculus theorem and in the other side one must find before the primitive ... @keewansadeq you must reflect on this ...
I noticed that as well. It could be that F is an antiderivative of f, or, as often happens, some posters mix upper and lower case for a single variable name.
@keewansadeq, did you intend f and F to represent different functions?
I assumed it was the integrand because there would not be a specific constant, like 2, in the anti-derivative. If the itegrand is f(x)= 3x+ 2, then the integrand is [itex]F(x)= (3/2)x^2+ 2x+ C[/itex] where C is a constant that will cancel in the definite integral. If the integrand is the constant, 3, then the anti-derivative is 3x+ C, to be evaluated at 2 and x on one side, 8 and x on the other.
@HallsofIvy I have had the same doubt the fact is that it is possible that in the text of the schedule they choose a particular primitive of ##3## with ##c=2##, I don't know because usually with ##F## denotes the primitive ...
Yes I did, Capital F means anti antiderivative
Actually,I am very goof in integration,but I am week in Fundamental calculus theorem, it is to me that derivative of integration will be the same function, that why I am confused.
Thanks all I appreciate
Samy_A said:
No.
This is simple
3(t^2)/2+2t
But the main problem is with Fundamental calculus theorem
Ok, so now we know that ##\int f(t) dt = F(t) + C##.
That means, by the fundamental theorem of calculus, that ##\int_a^b f(t) dt = F(b)-F(a)##.
Can you now compute ##\int_2^x f(t) dt## and ##\int_8^x f(t) dt##?
keewansadeq said:
This is simple
3(t^2)/2+2t
Sorry, but I don't see how you can say that: in another thread (on volume computation) you did another, considerably harder example without any difficulty at all!
Got it ,piece of cake, I just have small misunderstanding for something, and now it clear
Life is Hard
