Finding Maximum Distance from Sun
  • Thread starter Thread starter colourpalette
    Maximum Sun
To find the maximum distance (aphelion) from the Sun for an extreme elliptical orbit with a semi-major axis of 26 AU, the eccentricity should be close to 1, such as 0.99. The perihelion can be calculated as the sum of the radius of the comet and the radius of the Sun, which must be slightly larger than this sum to avoid contact with the Sun. The relationship between the semi-major axis and perihelion allows for the calculation of aphelion using the formula: aphelion = 2(semi-major axis) - perihelion. After calculations, the aphelion is approximately 51.995 AU, assuming the radius of the comet is negligible.
colourpalette
Find the maximum (aphelion) distance from the Sun for extreme elliptical orbit. (Semi-Major axis = 26)
Eccentricity = Distance between foci/Length of major axis
Major Axis = 2 * Semi-Major Axis
Major Axis = Perihelion + Aphelion
Eccentricity = Distance / (26*2) = Distance / 52
Eccentricity of an elliptical orbit is between 0 and 1, 0 being a circle.
What eccentricity should I be using for an extreme elliptical orbit?
My best guess would be right under 1 (ex: 0.99) but I'm not sure if that makes sense. (Would it be too close to the sun?)
Then once I have the distance between the foci, I would do semi-major axis - 1/2 distance between foci, in order to get the perihelion. From there I can get the aphelion.
What is the smallest possible value for perihelion?
Hm I'm not sure how to find this, it's not anywhere in my textbook and I've tried Googling this too. What can I do to find the smallest perihelion value?
Think about it for a bit. If I gave you any better hint than I did I would have given the answer away.
Remember that the sun is at a focus of the ellipse.
How does the distance between foci (and shape and position of the ellipse) change as the eccentricity becomes larger?
Hm.. The closest a comet can get without going through the sun would be r(comet)+r(sun), but that would mean it's touching the sun. It would have to be a little bigger than this? Am I on the right track?
As the eccentricity increases, the orbit goes from being a circle to a line, so the distance of the foci approaches the major axis of the whole orbit.. I'm not sure where to go from there.
Correct. So what does this tell you about perihelion, and thus about apihelion? (Hint: You know what the semi-major axis is.)
This means the perihelion is r(comet) + r(sun)? And therefore the aphelion would be 2(semi-major axis) - perihelion.
Aphelion = 2(26AU * 149 598 000 km/AU) - r(comet) - r(sun)
= 7 779 096 000 km - r(comet) - 695 500 km
I don't know the r(comet) but I'm assuming it would be negligible at this point? If so I'd get *huge number* and converting it back to AU would make it 51.995 AU! Is this correct?
Correct.
Thank you!
  • · Replies 19 ·
