Finding maximum temperature in Carnot cycle with 20 kW output and 12 kW heat rejection
3 replies · 3K views
db725
An ideal engine operating on the Carnot cycle with a minimum temperature of 25°C develops 20 kW and rejects heat a rate of 12 kW. Calculate the maximum cycle temperature and the required heat supply of the cycle.
Qhot/Thot =Qcold/Tcold
Since this is ideal entropy must be conserved. Δs hot =Δs cold is as far as I got.
Really stuck with this not sure how to go about it, any help would be greatly appreciated
Carnot Efficiency is n=1-(Qc/Qh), Qc is heat rejected, Qh is heat supplied
also Carnot efficiency is n=1-(Tc/Th)
Drawing a control volume around the device, (20 KW + 12 leaving) means 32 input or Qh=32, thus you have an efficiency, and then you can use this efficiency to solve for Th
So n=1-(12/32)=62.5% efficient
.625=1-(tc/th)
Tc/.375=Th thus 25/.375=66.67 C
hope that helps
