Finding optimal speed from a fuel consumption graph
  • Thread starter Thread starter 2000xjclassic
    Graph Optimization
1 reply · 3K views
2000xjclassic
We are given a graph of gallons of fuel per hour versus miles per hour and asked what speed should be used to maximize fuel efficiency and also what is the optimal speed(are these two the same thing).
I understand optimization using the first derivative when given an equation, I am having a problem with figuring out what to do with only a graph
I have graphed the first derivative. should I use the zero points from the first derivative graph to optimize the fuel efficiency?
Thanks in advance.
Chris
"Optimal" simply means "best". IF "optimal" here means "best fuel efficiency", then they are the same.
Thanks in advance.
Chris
Yes, the max or min points will be where the first derivative is 0. I don't know that you really needed to graph the entire derivative. The derivative will be 0 where the original graph has a horizontal tangent.
