Finding Orthogonal Vectors in R^5 without Cross Product
2 replies · 4K views
phil ess
Given vectors a=(1,-1,0,2,1) b=(3,1,-2,-1,0) and c=(1,5,2,4,-4), which are mutually orthogonal, find a system of linear equations that a vector x must satisfy so it is orthogonal to a, b, and c.
None I think.
This is part A of the problem, after which I just have to solve the system and I'm confident I can do the rest once I have it, but I don't know where to start. I tried using the equations:
x1-x2+3x4+x5=0
3x1+x2-2x3-x5=0
x1+5x2+2x3+4x4-4x5=0
And then just solving the matrix, which gives me
x=(0,0,0,0,0)+s(-8,2,-11,5,0)+t(-5,5,-6,0,2)
But I'm pretty sure this doesn't answer the problem. I don't know how to create a system that gives orthogonal solutions, and the above solution isn't even a vector as far as I know. How do I start this problem? Any tips are much appreciated! Thanks.
You are doing exactly the right thing, except there seems to be some typos in your equations. How did you get the 3 in the first one and why is there an x5 and not an x4 in the second one. Your result isn't 'a' vector, it's a two parameter family of vectors, which is exactly what you should get, but the numbers aren't quite right either.
I understand the problem now, and I went back and reworked everything carefully and ended up with the right solution. It was actually much easier than I thought at first. Thanks a lot!
