Finding output current as function of voltage difference using circuit redrawing
  • Thread starter Thread starter Master1022
    Circuit
Master1022
Find an expression for the current out as a function of the difference between the input and output voltage when the reference voltage is the same as the output voltage
V = IR
Hi,
I was attempting this problem where the aim is to find the output current as a function of the voltage difference ## P_{in} - P_{out} ##. I just have two quick questions about this circuit:
1. If the 'reference voltage' (which I assume is how the ground voltage is referred to) is the same as the output voltage, am I correct in thinking that I can ignore the last capacitor ## C_v##?
2. Am I allowed to re-draw the following circuit such that the bottom connection wire is removed? It doesn't make any difference to my analysis, but just wondering?
3. Does my attempt below look like it is on the right tracks?
re-drawn as:
Attempt:
Making the above assumptions, we could use KVL to get an equation for the first junction, which we can denote as ## P_x ## (in ##s##-domain):
[tex]\frac{P_{in} - P_{x}}{R_a + I_a} + \frac{P_{ref} - P_{x}}{\frac{1}{s C_a}} + \frac{P_{out} - P_x}{(R_c + R_v) + s I_v} = 0[/tex]
and an equation for the output junction as:
[tex]\frac{P_x - P_{out}}{(R_c + R_v) + s I_v} + \frac{P_{ref} - P_{out}}{\frac{1}{s C_v}} = i_{out}[/tex]
which then simplifies to: (if ## P_{ref} = P_{out} ##)
[tex]\frac{P_x - P_{out}}{(R_c + R_v) + s I_v} = i_{out}[/tex]
which I can then go on to solve. However, I cannot easily see how this will take the form of an LPF. When re-drawing the circuit above, it looks as if it turned into two potential dividers, each of which had a transfer function of the form:
[tex]\frac{1}{1 + sRC + s^2 LC}[/tex]
When cascaded without making any assumptions about the reference voltage, it looks as if the complete circuit would form a fourth order LPF... I can't seem to reconcile these two viewpoints.
Any help is greatly appreciated.
You can draw the reference as you did in the second picture okay.
The letters are used in an unusual way here. I mostly see ##V## used instead of ##P## because ##P## is usually used for power; inductors usually use ##L## because ##I## is typically used for current.
The first equation you accidentally dropped the ##s## in front of the inductor A. In the second equation is there something else connected after what you called ##P_{out}##? I don't think so. If there isn't, then you should be saying the sum of the currents is equal to zero instead of ##i_{out}##.
I don't understand the last part why you would say ##P_{ref} = P_{out}##. Are you meaning to short the output to the ground reference? That's very unusual. I don't think that's right. I think you were meaning to say that ##P_{ref} = 0##. I would recommend trying that unless you could clarify on what you were intending to do?
Thank you very much for your reply @Joshy ! Apologies, I should have added more context to the post. This question is within the general topic of haemodynamics and thus some of the naming conventions are different. However, I didn't include the context in fear that it may just overcomplicated a question which is, at its core, just a circuit analysis question.
Okay thank you.
Indeed, so in this case the ## P ## is actually "pressure", but this question actually uses it in an analogous way to voltage (i.e. the pressure is the driver and the blood flow is the flux). With the inductance, I am not sure why they change the convention, so I do agree (especially as this is going to be analyzed with circuit theory concepts).
Yes, thanks for spotting that. Apologies for the typo!
I was thinking the same thing and I am not sure whether there is anything else afterwards. The reason I did that is because of the following (the only example of this content in the lectures) shown in the image below.
It also uses ## q_{out} ## instead of 0 for some reason. I will keep thinking to see why that is the case.
Yes, I do agree. However, that is what I interpreted the wording of the question as saying. The wording of the question is:
"Find an expression for the current out as a function of the difference between the input and output voltage when the reference voltage is the same as the output voltage"
(Note: I changed the words pressure for voltage and blood flow for current, but wording is otherwise the same)
Perhaps there is a typo in the sheet and I ought to ask the teacher.
