Finding raindrop radius at terminal velocity using Stokes law
5 replies · 4K views
IDK10
Using the viscosity of air as 1.8x10-5Pa s, and the density of water as 1x103kg m-3, find the radius of a raindrop traveling at a terminal velocity of 7.05ms-1. Assume Stokes law can be used.
The problem is finding the density of air, I could use F = 6rvπη but I don't know F, because it says in a previous question to assume that in D + U = W, to assume U is negligible, and I don't know the weight, because I don't know the mass or volume of the raindrop.
r = sqrt((9ηv)/(2g(ρ-σ)))
Without a density of air, I get 9.31x10-5m, but that would be wrong since the density of air is not being included.
Density of air is a small correction, so you can use the ideal gas law to find its approximate value.
Google "density of air" .(It is about 1.225 kg/m3)
And check your numerical result.
If by buoyancy you mean upthrust, then no, a previous part of the question says it is neglibible. So its just F = W.
It is not correct, but not because of neglecting the density of air.
