Finding resultant force location for distributed beam loading
  • Thread starter shreddinglicks
11 replies · 5K views · last reply
shreddinglicks
Replace the distributed loading with an equivalent resultant
force, and specify its location on the beam measured from
point O.
W = 3 kn/m
F*xbar = torque
I got the resultant forces:
(1/2)*3*3 = 4.5 kn
(1/2)*1.5*3 = 2.25 kn
4.5 + 2.25 = 6.75 kn
I know my general equation is:
6.75*xbar = torque
I want to solve for xbar.
xbar should equal 2.5m
  • Beam fixed at wall point O on the left, with a triangular distributed load w0 peaking at the centre, spanning 3 m to the peak and 1.5 m to the right end.
What's the centroidal location of a right triangle? Your distributed load can be broken up into two triangular loads.
I'm unsure, could you explain it to me?
If the centroid of a rectangle is located at half the length or half the depth, what is the centroid of a triangle?
If you're still stumped, you can always google 'centroid of right triangle'
If I multiply both distances by 1/3, I still do not get the proper answer.
I see, so when I approach the triangle from the one side I have 1/3 so the rest must be 2/3. But how do I know which is the 1/3 side and which is the 2/3 side?
If you have a right triangle with the pointy end at O, how far from O will the centroid be, 1/3 of the length of the base or 2/3 of the length of the base?
Remember, the location of the centroid coincides with the balance point of the triangle.
It would have to be 2/3.
So, if I had a problem where I had to find, say a location at point, "A" that was directly under W. The distance would then be 1/3 for each triangle?
I'm not sure what you are asking here. The choice of whether to use 1/3 or 2/3 of the length of the base as the centroid depends on the orientation of the triangle.
I meant a situation like the one pictured. I would use 1/3 for each triangle, and I would use 1/2 for the rectangle, correct?
  • Beam diagram with a trapezoidal distributed load: intensity rising from 800 lb/ft at the left end A to 500 lb/ft at the right end, with downward arrows. Support A at the left end and support B below the beam; spans marked 12 ft from A to B and 9 ft from B to the right end.
1/3 of the base for each triangle would be OK, as long as the reference was taken about a vertical line running thru the support at B.
