Finding separation of bright spots
  • Thread starter Thread starter omc1
    Separation
4 replies · 3K views · last reply
omc1
A scientist decides to do the double-slit experiment in a vertical tube, with the slits at the top and a viewing screen at the bottom as shown. With red light from a HeNe laser (632 nm) a nice pattern forms on the viewing screen, with the bright spots 1.00 cm apart.
Now the scientist fills the tube up with water. What is the separation of the bright spots now?
i used v=c/n v=λf y=m(λ)L/d
λ=c/nf plugged that into y(initial)=m(λ)L/d, i used 1.33 as the index number. y(final)=m(λ)L/d to find the new separation, the m, L, d cancel out leaving y=λ or y(final)=c/nf c=3x10^8, n=1.33, f=632x10^-9 meters, i got 3.5x10^14 which seems to me to be really large...please help its due tonight, thanks!
wait, i don't see how that equation applies here? i don't see how sin(theta) works here?
omc1 said:
y(initial)=m(λ)L/d, ... y(final)=m(λ)L/d
But the lambdas are different, right?
I don't understand how you arrived at that. y is the band separation, lambda is the wavelength of the light. Why should they be equal?
f=632x10^-9 meters
f is frequency, surely, not wavelength.
In air:
If θm is the angle subtended at maximum number m, then d sin θm = mλ.
In water:
if θ'm is the angle subtended at maxium number m, then n*d sinθ' = mλ'.
For both air and water, for m = 0 we get the center maximum. For m = 1 we get the first separation.
The ratio of sinθ'm/sinθm is the same as the ratio of screen spacings in air vs. in water.
You know n, λ and λ' so you know the sine ratio and therefore the spacing ratio. Use m = 1 for the spacings for both cases.
