Finding speed of objects after elastic collison
12 replies · 4K views · last reply
joe426
1/2m1v12 + 1/2m2v22 = 1/2m1v1f + 1/2m2v2f
m1v1 + m2v2 = m1v1f + m2v2f
v1 - v2 = -(v1f - v2f)
So I solved the momentum of conservation for the final velocity of object 1. I then plug that equation into the third equation listed above, as v1f. But the thing is the equation i get for v1f has v2f in it and that is what I am solving for and this is where I am stuck.
I don't think any of the velocity equals 0 at any point. Initially they are moving in the same direction. Then since it says its perfectly elastic, one object will bounce back and have a velocity in the opposite direction. I think the 60g tennis ball will bounce back in the negative direction but I still can't figure out how to find the velocities after the collision :(
First use conservation of momentum
( m1v12 + m2v22 - m2v2f2 ) / m1 = v1f2
Then plug this v1f into this helper equation, the third equation listed in first post.
v2f = v1 - v2 + [( m1v12 + m2v22 - m2v2f2 ) / m1 ]1/2
And I'm stuck because I can't get both v2f to one side so i can solve for it. then once i get v2f i plug it back into the first equation, [( m1v12 + m2v22 - m2v2f2 ) / m1 ], and solve for v1f
Use the last two equations. Plug in the numbers first. Express v1f from the third equation.
ehild
Use the last two equations. Plug in the data first, express vif form the last equation, and substitute into the second one.
ehild
v1f = -v1 + v2 - v2f
Plugged that into,
(m1v1 + m2v2 - m1v1f) / m2 = v2f
v2f = -.368m/s
Check it.
ehild said:
Check it.
v1f = -v1 + v2 - v2f is really v1f = -v1 + v2 + v2f. ..
(m1v1 + m2v2 - m1v1f) / m2 = v2f turns into (m1v1 + m2v2 + m1v1f) / m2 = v2f
so v2f = .307m/s
Check.
ehild
Plug in the numbers for v1 and v2: v1f = v2f - 1.35.
Plugging in the data into the equation m1v1+m2v2=m1v1f+m2v2f and also substituting v2f - 1.35 for v1f: 0.2535 = 0.06(v2f - 1.35)+0.09v2f.
Expand and collect the terms with v2f, solve.
ehild
Munzi5 said:
Its 3.75 or 1.35?
What is 3.75 or 1.35?
ehild
