Finding spring constant from two equilibrium lengths
11 replies · 2K views · last reply
Naldo6
An elastic cord is 67.7 cm long when a weight of 58.7 N hangs from it and is 85.8 cm long when a weight of 88.1 N hangs froms it. What is te spring constant of this elastic cord?
how i know which is the long of the spring when it is in equilibrium to then calculate the sprin constant?...
or anyother help to solve this problem
Hello once again,
A review of Hooke's Law will reveal that the k, the spring constant, is a constant of proportionality. This means that F_1/x_1 = F_2/x_2 where x is the extension of the spring. Does this shed any light?
Regards,
Horatio
ok but if i do that what i can get:
because
58.7 N / .677 m = 88.1 N / .858 m
and that doesn't help me too much... because i don't know the distance of the spring when it is at equilibrium
because
That's not exactly true. Remember, x is the extension of the spring, not the length of the spring. So, if we let the equilibrium value be l , the extension in one case is (0.677 - l). Does that clear things up?
ok i know that x is the value of the extension of the spring but how i know whta is the extension of the spirng when is at equilibrium to then calculate the extension from the diferencies of my value sof x with the equilibrium distance?...
Since the extension x = (length of spring with load - length of spring at equil.):
The eqn shld be:
58.7 / (0.677 - l) = 88.1/ (0.858 - l)
where l is the equil. length, solve for l, with is simple algebraic manipulation...
solving for l y get 0.316... then i use F=kx solve for k and get
k= F/x = 58.7/(0.677-0.316)=162.60 is this right?
