Finding sum to convergent series?
The discussion focuses on determining the convergence of the series Ʃ (3^n + 2^n)/6^n as n approaches infinity. The series can be separated into two geometric series: Ʃ (3/6)^n and Ʃ (2/6)^n. The common ratio (r) for the first series is established as 1/2, leading to a convergent series with a sum calculated using the formula a/(1-r). The second series converges as well, but its contribution becomes negligible in comparison to the first series.
  • Understanding of geometric series
  • Familiarity with convergence tests
  • Knowledge of series summation formulas
  • Basic algebraic manipulation skills
  • Review geometric series and their convergence criteria
  • Learn how to apply the formula for the sum of a geometric series
  • Explore the concept of dominant terms in series
  • Study convergence tests for series beyond geometric series
Students studying calculus, particularly those focusing on series and sequences, as well as educators teaching convergence concepts in mathematics.
MySecretAlias
Decide whether convergent or divergent, if convergent, find sum.
Ʃ as n = 1 and goes to infinity > (3^n + 2^n)/6^n
a/1-r
I'm just confused where to find the "r" to this without actually plugging in values for n, then dividing. For example, to get the answer (at least I think it's correct), I plugged 1 in for n, got 5/6, then i plugged in 2 for n, and got 11/36. I did (11/36) / (5/6), and used that for my r value, plugged that into a/1-r, and got about 1.31
How exactly do I find the r value? Thanks.
Try breaking it into two sums,
\sum \frac{3^n}{6^n}+ \sum \frac{2^n}{6^n}
If those converge, separately, then the combination converges to the sum of those two.
I respect that. Thank you. However, how do i find what the sum is?
Write 3^n/6^n as (3/6)^n=(1/2)^n. It's a geometric series. You've probably covered those.
Does this mean that r value is simply 1/2? the 2^n does not really matter, since in the long run, it becomes so miniscule?
Of course the 2 matters, otherwise it wouldn't be (1/2)^n. What's the sum for n=1 to infinity of (1/2)^n? Review geometric series if you have to.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
