Finding the critical angle for total internal reflection
5 replies · 2K views · last reply
jegues
See figure attached for problem statement.
Using Snell's Law,
[tex]n_{1}sin(\theta_{1}) = n_{2}sin(\theta_{2})[/tex]
[tex]n_{1} = \frac{n_{2}sin(\theta_{2})}{sin(\theta_{1})}[/tex]
Where,
[tex]\theta_{1} = 30^{o}, \theta_{2} = 90^{o}[/tex]
It gives me, [tex]n_{1} = 2[/tex] but the answer is a minimum of 1.15.
What did I do wrong/misunderstand?
  • Multiple-choice physics question 10 with a diagram: a dashed ray enters a glass prism horizontally, meets the slanted face at a 60 degree angle marked against the vertical edge, and is labelled air above and glass below. Options: (a) at least 2.0, (b) at most 2.0, (c) at least 1.15, (d) at most 1.15, (e) cannot be calculated.
tiny-tim said:
hi jegues! :smile:
it's not 30°, it's 60° :redface:
Yes I figured that much but I don't understand why.
I'm looking at the triangle and the angle at the bottom right should be 90-60 = 30, that's where the incident angle is isn't it?
hi jegues! :smile:
jegues said:
… the angle at the bottom right should be 90-60 = 30, that's where the incident angle is isn't it?
nooo :redface: … the angles of incidence and refraction are always from the normal :wink:
tiny-tim said:
hi jegues! :smile:
So a line perpendicular to the surface it's hitting, right?
