Finding The Equidistant of 2 Points
5 replies · 8K views · last reply
Ecom
I need the formula for finding the coordinates of the point on the y-axis that are equildistant from two other pair of points (3,0) and
(3,6).
i don't know, but these might have something to do with it.
[tex]\sqrt{}[/tex] (y2-y1)2+(x2-x1)2
(x2+x1[tex]/[/tex]2, y2+y1[tex]/2[/tex])
I found the midpoint of (3,0)-(3,6), and found the distance between the midpoint to the endpoints, but i don't know were to got from there. I also tried writing random scribbles on my graph papers, crying, begging God to take me out of IB extended math, and finally, posting on Physics Forums for help.
Hint: Points equidistant from your two points would be on the perpendicular bisector of the line joining them. Draw a sketch.
Ah Yes, but that would be too easy!:wink: I need to find the anwser using an equation.
Sure. Solve for the mid-point between your points. Write the equation of the perpendicular bisector. Solve for where it hits the y axis. The picture was just to lead the way.
ohhhhhhhhhhh...
Probably should have looked up "perpendicular bisector". I knew what perpendicular meant, but you threw me off at bisector.
Anyway, thanks for the information. Saved me hours of going over "attempt at solution" again
This is particularly simple because it is a vertical line. Any line perpendicular to it is a horizontal line and has the equation "y= constant". But the problem is finding that constant. To do that you need to know the y-component of the midpoint, which was what the original question asked!
It should be obvious what the x-component is. What point is half way between 0 and 6 on the number line?
