Potential difference between 2 points in a capacitor circuit
30 replies · 5K views · last reply
The solution for defining a battery as infinite C implies dV/dt = I/C =0 regardless of the charge transferred or its rate of flow which is current. So we assume a charge is simply transferred in this case from the higher voltage to the lower voltage battery and the conservation of charge equations then only involve the other components. So in the end it doesn’t affect the result but at least it passes the sniff test for reality in physics.
I posted the correct assumption in #11 if if C1V1+C2V2=0.
Also from KVL, V1+V2 +24-12V =0 and if C2=2C1
Thus for C1=2 uF and C2=4 uF
you have 2 equations and 2 unknowns, solve it and what are V1,V2?
