How Is Force Calculated on an Inclined Plane with Friction?
  • Thread starter Thread starter vipertongn
    Block Force
The discussion centers on calculating the force required to move a 20-kg package up an incline with friction. The applied force P is initially calculated as 419 N for impending motion and 301 N during sliding, but the calculations yield different results based on the angle definitions used. Participants highlight confusion over the angles in the free-body diagrams, particularly how the angle of P relates to the incline. There is uncertainty about the static coefficient of friction being 0.3, suggesting a potential error in the provided solution. The conversation emphasizes the need for clarity in angle definitions and the equations used to ensure accurate calculations.
vipertongn
A 20-kg package is at rest on an incline when a force P is applied to it. Determine the magnitude of P if 10s is required for the package to travel 5m up the incline. The static and kinetic coefficients of friction between the package and the incline are both equal to 0.3.
Answer: 419N to start and 301 during sliding
m=20kg
g=9.8m/s2
t=10s
xi = 0ft
xf = 5ft
μs = μk = 0.3
Frictional force = Ff = μN
First, I drew a free-body diagram including tilted coordinate axes:
Then, I went about finding the sum of the forces equations in the x- and y-directions.
\sum F_{x}=-F_{f}-mgsin(20)+Pcos(30)=ma
\sum F_{y}=N-mgcos(20)-Psin(30)=0
From the second equation,
N=mgcos(20)+Psin(30)
Plugging this value for N into Ff = μN in the first equation yields:
P=\frac{ma+\left(\mg(mu cos(20)+sin(20)\right)}{cos(30)-\mu sin(30)}
My problem is that I know for impending motion you set a= 0 so plugged in I get
P=296 N
and for motion I get
P=301
Problem is the first P is suppose to be 419 and I don't know why I'm not getting the right answer.
I don't think you have made the direction of P clear.
The angle is not mentioned at all in the question.
In your upper diagram, it is shown 30 degrees below horizontal.
In your lower diagram, it is shown 30 degrees below the angle of the ramp.
Can't be both.
\sum F_{x}=-F_{f}-mg \sin(20)+P \cos({\color{red}30})=ma
\sum F_{y}=N-mg \cos(20)-P \sin({\color {red}30})=0
N=mg \cos(20)+P \sin({\color{red}30})
(Red emphasis mine. Also made a slight modification to the "sin" and "cos" notation in LaTeX.)
The force P is 30o with respect to the horizontal But your definition of the x-axis is not the horizontal. What angle is P with respect to your definition of the the x-axis?
[Edit: Delphi51 beat me to the hint.]
ohh it was drawn wrong...ok the new angle for P is 50 degrees from the horizontal of my new axis. I made my new equation to be
P= ma+mg(sin20+ mu cos20)
cos50- mu sin 50
I didn't get the same thing. Doesn't mean you're wrong, but it would be nice to synchronize our work.
For normal force, I have Fn = mg*cos(20) + P*sin(40).
Do you agree?
I'm not sure about that, i used 50 degrees because i set the x-axis to be the same as the block, and then used the transversal angles are equal...so adding 20 to 30 degrees to get that. It's ironic because when I solved for the motion...it came to the correct answer of 301, but for the first answer it doesn't work...and the only difference is adding 2 (ma) to the numerator
You could write it as cos(50) instead of sin(40).
Fn = mg*cos(20) + P*cos(50)
yea but the overall equation still doesn't make out to be 419 as shown in the solutions
Are you sure that the static coefficient of friction is also 0.3? Is everything related to the problem given in the problem statement (nothing left out)? If so, I think there might be some sort of mistake in the given solution regarding the "419 N to start" answer.
16K
  • · Replies 19 ·
  • · Replies 17 ·
14K
9K
