Finding the force of reaction as a function of time
The discussion revolves around finding the force of reaction as a function of time, with references to Newton's second law and the relationship between force, mass, and acceleration. The original poster expresses uncertainty about their approach to deriving this function.
  • The original poster attempts to integrate force with respect to time and velocity, leading to a proposed function F(t) = MV. Some participants question the validity of this conclusion and suggest that the integration steps may not be correctly applied.
Participants are actively engaging with the original poster's approach, providing feedback and suggesting that the reasoning may need refinement. There is a focus on clarifying the mathematical relationships involved, but no consensus has been reached on the correct method.
There are indications that the original poster's problem may be similar to an older thread, and participants are encouraged to provide more details about their specific issues and attempts. Some guidance has been offered regarding the correct application of equations, but the discussion remains open-ended.
jumboopizza
the only part of the question I am unsure about is finding the force of reaction as a function of time
F=Ma
F=-Kx
F=Ma
F=M(Dv/Dt)
F Dt= M Dv
i integrate force with respect to time from final time=t and initial time = 0
integrating M with respect to velocity from final velocity=V and initial velocity=0
I get F(t)=MV
is this the correct way to get the force as a function of time?
did you find the solution
This thread is ten years old!
I know but I also have a problem that is very similar to that one . how do you find the force as a function of time
Make a new thread in homework forums please and be sure to post as many details as you can about your problem and attempted solution, including the exact statement of the problem as it is given to you.
What the OP does here is not entirely correct. From ##Fdt=MdV## it is not correct to conclude ##F(t)=MV##, it should have been ##dF=MdV## in order to conclude that.
ok thank you very much
Ummm, make that ##F = M \frac{dV}{dt}##. Which would more conventionally have used a lower case M and V and would be commonly written as: ##F=ma##
One could start with ##F=\frac{dp}{dt}##, take the definition of momentum ##p## as ##mv##, substitute to arrive at ##F=\frac{d(mv)}{dt}## use the product rule for differentiation and get ##F=m \frac{dv}{dt} + v \frac{dm}{dt}##, take m as a constant so that its derivative is zero to get ##F = m \frac{dv}{dt}## and then use the definition of acceleration to rewrite that as ##F=ma##.
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 21 ·
