MHB Finding the LCM of two expressions
  • Thread starter Thread starter zolton5971
    Expressions
To find the least common denominator (LCD) of the expressions 3(2x-2) and x(5x-5), it's essential to factor each expression. The correct LCD involves identifying the highest powers of each factor present in both expressions. After simplifying, the expressions can be represented as 6(x-1) and 5x(x-1). The final LCD can be calculated by multiplying these factors together, ensuring all variables and polynomials are treated as prime factors in the process.
zolton5971
Find the least common denominator of 3(2x-2) and x(5x-)5
I wanted to double check this, I got 10 as an answer? If not how would you get the LCD?
Mathematics news on Phys.org
Do you mean $$x(5x-5)$$? You're answer should include $$x$$ somewhere
The lowest common multiple (LCM) is given by splitting each term into prime factors and multiplying by the highest power of each prime factor. For example to find the LCM of 10 and 15 (it's 30) you'd do
$$10 = 2 \times 5 \text{ and }\ 15 = 3 \times 5[/math] so the LCM is given by $$2 \times 3 \times 5 = 30$$
You can do the same with algebraic fractions but remember to treat any polynomials or variables as prime - after simplifying you have $$6(x-1)$$ and $$5x(x-1)$$
Can you use the method above to find the LCM?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
