Finding the limit of √(x² + 1) as x → ∞
  • Level: Undergrad
  • Thread starter Thread starter SprucerMoose
    Infinity Limit
8 replies · 5K views
SprucerMoose
Gday,
I was contemplating limits today and tried to prove something to myself and I can't figure it out.
This is what I am trying to wrap my head around.
http://latex.codecogs.com/gif.latex?\lim_{x \to \infty } \sqrt{x^2 + 1}
I'm not looking for the "numerical" solution of infinity, what I am trying to prove is that as x approaches infinity, this expression approaches x.
I then came to this conclusion.
http://latex.codecogs.com/gif.latex?\lim_{x \to \infty } \sqrt{x^2 + 1} = \lim_{x \to \infty } \sqrt{x^2(1 + \frac{1}{x^2})} = \lim_{x \to \infty } x\sqrt{1 + \frac{1}{x^2}} = x\sqrt{1 + 0} = x
Is this logic correct? I can't see why it wouldn't be. But this way of thinking leads to a scenario that I am not happy with.
http://latex.codecogs.com/gif.latex?\lim_{x \to \infty } \sqrt{(x-1)^2 + 1} = \lim_{x \to \infty } \sqrt{x^2 - 2x +2} = \lim_{x \to \infty } \sqrt{x^2( 1 - \frac{2}{x} +\frac{2}{x^2})} = \lim_{x \to \infty} x\sqrt{1 - \frac{2}{x} + \frac{2}{x^2}} = x\sqrt{1 - 0 + 0} = x
I am reasonably certain that the solution to this particular expression should be http://latex.codecogs.com/gif.latex?\lim_{x \to \infty } \sqrt{(x-1)^2 + 1} = x - 1 .
Can someone please tell me where I have gone wrong?
SprucerMoose said:
[tex]\lim_{x \to \infty } x\sqrt{1 + \frac{1}{x^2}} = x\sqrt{1 + 0}[/tex]
This is where you have gone wrong. x is a variable in the limit. And when you calculate the limit, there is no way that there could be an x in the solution.
Thanks for the response.
So how would I prove the existence of the asymptotes of a hyperbola for example, or other oblique asymptotes for that matter?
Same method - evaluating the limits - except you will get a constant based on the properties of the hyperbola, not on x.
I'm still stuck.
http://latex.codecogs.com/gif.latex?\frac{(x-1)^2}{4} - \frac{y^2}{9} = 1
http://latex.codecogs.com/gif.latex?y = \pm \sqrt{\frac{9(x-1)^2}{4} -9}
http://latex.codecogs.com/gif.latex?\lim_{x \to \infty} \sqrt{\frac{9(x-1)^2}{4} -9}
http://latex.codecogs.com/gif.latex?\lim_{x \to \infty} \frac{3}{2}\sqrt{(x-1)^2 -4}
What would I need to do to prove this expression approaches
as x approaches infinity?
Here's what I would do.
[tex]\frac{(x- 1)^2}{4}- \frac{y^2}{9}= 1[/tex]
[tex]\left(\frac{x-1}{2}+ \frac{y}{3}\right)\left(\frac{x-1}{2}- \frac{y}{3}\right)= 1[/tex]
For x and y both very large positive numbers,
[tex]\frac{x-1}{2}+ \frac{y}{3}[/tex]
will be a very large positive number.
For x and y both very large negative numbers,
will be a very large negative number.
In either case, we can divide both sides by it and get
[tex]\frac{x-1}{2}- \frac{y}{3}= \frac{1}{\frac{x-1}{2}+ \frac{y}{3}}[/tex]
so that
[tex]\frac{x-1}{2}- \frac{y}{3}\approx 0[/tex]
so that
[tex]\frac{x-1}{2}\approx \frac{y}{3}[/tex]
If x and y are large but of different signs, then
[tex]\frac{x-1}{2}- \frac{y}{3}[/tex]
will be a large positive number (if x is positive and y is negative) or a large negative number (if x is negative and y is positive). In either case, we can divide both sides of the original equation by
to get that
[tex]\frac{x-1}{2}\approx -\frac{y}{3}[/tex]
This seems to be confusing to me; the limit itself approaches infinity; you are looking for asymptotes. I mean, as x approaches infinity, so does the function. Its asymptote, though, it that equation you posted. I think it's abuse of notation, somehow, to find the function of the asymptote while using x as the variable in the limit? (it causes this confusion).
HallsofIvy, thanks so much. That's heaps better. But I'm still wondering what the process is to find the function that an expression approaches while tending to infinity and is under a square root. I have no problem calculating oblique asymptotes when i can use polynomial long devision, but cannot find a way to calculate the limits I originaly posted.
Please tell me there is a method.
[edit] I guess I'm not looking for the actual limit, but rather the function of the oblique asymptote. Poor notation on my part. How would I set up the original (not the hyperbola) problem with correct notation?
Why not show the correct way, as opposed to just saying it is wrong?
The problem, as micromass said, is that x is the variable of the limit, and is only defined within the limit. You must say [tex]\lim_{x \to \infty } x\sqrt{1 + \frac{1}{x^2}} = \lim_{x \to \infty } x\sqrt{1 + 0}[/tex] and you can only remove the [tex]\lim_{x \to \infty }[/tex] when you have either found the limit, in terms other than x, or you've found that there is not limit.
As for why it doesn't work if you expand the binomial, I don't know. But, the way you can get the right answer is to [tex]\lim_{x \to \infty } \sqrt{\left( x-1 \right)^2 +1} = \lim_{x \to \infty } \sqrt{\left( x - 1 \right)^2 \left(1 + \frac{1}{\left( x - 1 \right)^2} \right) }[/tex] and continue the obvious.
