Finding the magnitude of a particle from a graph?
The discussion revolves around calculating the displacement and average velocity of a particle based on a graph of its acceleration. For the first question, the user is confused about interpreting the graph to determine displacement over specified time intervals, particularly regarding the acceleration values. The second question clarifies that zero acceleration means the particle maintains a constant velocity during that period. For the average velocity calculation, the user initially miscalculates by summing positions instead of finding the total displacement from the initial to final position. The conversation emphasizes the importance of correctly applying the physics equations and understanding the definitions of displacement and average velocity.
themadcow45
Consider the acceleration of a particle along a straight line with an initial position of 0 m and an initial velocity of 0 m/s.
1) Calculate the magnitude of the displacement after the car travels the first 5 s.
Answer in units of m.
2) How far does the car travel from 9 s to 13 s, if it does not experience any acceleration during this time period?
3) Calculate the magnitude of the car’s average velocity from 5 s to 9 s.
Answer in units of m/s.
x - x0 = v0t + (1/2)at2
For 1), I guess I'm confused at how to be reading the graph. I've tried breaking it up into 0 to 1 s, 1 to 3 s, 3 to 4 s, and 4 to 5 s, and using the equation above to find the displacement for each interval, but I'm getting confused as to where the acceleration is located on the graph. For example, is the acceleration at t = 3 s supposed to be 2 m/s2 or 0 m/s2?
For 2), when it says that it doesn't experience any acceleration, does that mean acceleration = 0?
For 3), what is the equation for average velocity?
Any help/hints would be appreciated, thanks!
Consider thinking in terms of open intervals (mathematically speaking) when the endpoints are discontinuous. So intervals might be:
0 ≤ t < 1
1 ≤ t < 3
3 ≤ t < 4
4 ≤ t < 5
5 ≤ t < 6
and so on.
The end-point value that you use in your equations for any interval should reflect the value that the variable had within that interval immediately adjacent to the endpoint.
Yes.
Average velocity is defined to be the total displacement divided by the time.
Hi gneill,
So for 1), here's my work:
0 to 1: x - 0 = 0(1) + .5(0)(1)^2 = 0
1 to 3: x - 0 = 0(2) + .5(2)(2)^2 = 4
3 to 4: x - 4 = 4(1) + .5(1)(1)^2 = 8.5
4 to 5: x - 8.5 = 4(1) + .5(1)(1)^2 = 13
Would 13 be the correct answer, or am I missing anything?
Between 3 and 4 seconds the acceleration should be zero. So only the current velocity (from the end of the last stage) should be affecting the distance.
You can move the initial position values to the RHS of your equations so that the equations make algebraic sense for the final equals sign. So for any given step:
xnew = xp + vp*Δt + (1/2)*a*(Δt)2
vnew = vp + a*Δt
where the "p" subscript refers to the value at the end of the previous step.
I've gotten everything except the last problem;
Here's my work so far:
5 to 6: v = 13, x = 21.5
6 to 8: v = 11, x = 45.5
8 to 9: v = 3, x = 52.5
You said the average velocity is total displacement divided by the time, so it would be:
(21.5 + 45.5 + 52.5) / 4, right? But that answer is coming out as wrong...does anyone know what I'm doing wrong?
I also tried (13 + 3) / 2, but that's wrong as well.
You want the distance traveled during the specified time period, divided by the length of the time period.
What is the displacement at the beginning of second 5? At the end of second 9?
Oh...I think I understand...So it would be (21.5 + 52.5) / 4 ?
Is 21.5 the displacement at the beginning of second 5 (same as end of second 4)?
Ah, I read your previous post wrong, my fault... it would be 12.5.
But would 52.5 still be the end point, right, since you can't extend the graph to t = 10?
Correct.
gneill said:
Correct.
(12.5 + 52.5) / 4 is coming out to be incorrect...Any tips on what I'm doing wrong?
Total displacement is the final position minus the initial position. Don't sum them!
D'oh. Physics isn't my thing, but thanks for the help gneill - you've been invaluable in your patience and quick responses. Thank you!
