Finding the matrix of a transformation
5 replies · 6K views
Cankur
Consider the transformation T from R2 to R2 that rotates any vector x through an angle of 45 degrees in the counterclockwise direction. You are told that T is a linear transformation. Find the matrix of T.
A vector with components x1 and x2 should become x 2 and x1, seeing that the transformation should rotate the vector 45 degrees. So therefore, the matrix of the transformation should be:
[0 1]
[1 0]
The rotation you're describing here is a rotation of 90° counterclockwise, not 45°.
What should T do to x1 = <1, 0> and x2 = <0, 1>?
[0 1]
[1 0]
[0 1]
[1 0]
No, with a 45 degree rotation, any vector on the x-axis (y=0) would rotate to the line y= x while any vector on the y-axis would rotate to the line y= -x. What vectors on those lines have length 1?
It should move it half of 90 degrees. But what matrix would achieve that? A matrix that looks like this perhaps:
[0 1/2]
[1/2 0]
How should you think when you have problems of this sort?
[0 1/2]
[1/2 0]
No, the matrix above doesn't work.
I'll ask this again.
Which (because I just have to jump in behind Mark44) is much what I asked before: what vector, <x, x>, has length 1? What vector <-x, x>, has length 1?
