Finding the nth roots of a complex number
To find the sixth roots of the complex number i, the argument is calculated as π/2 with a modulus of 1. The roots are expressed in exponential form as r^(1/6)e^(i(5kπ/12)), where k ranges from 0 to 5. There is confusion regarding the addition of terms involving k, with some suggesting to leave it in expanded form and substitute k-values directly. It is clarified that k can be any integer, allowing for both positive and negative values to yield all distinct roots. The discussion emphasizes the importance of correctly applying periodicity in trigonometric functions and the need for careful substitution to match expected results.
charmedbeauty
find the sixth roots of i.
So I started by
Arg(z)=pi/2 and |z|=1=r n=6
so z= r^(1/6)*e^i((5kpi)/12) for k=0,1,2...n-1
and that's as far as I got
and there answer = e^i*n*pi/12 for n= -1, -7, -3, 1, 5, 9
Did you add (\frac{\pi}{12} + \frac{4k\pi}{12}) to get \frac{5k\pi}{12}?
I don't think you can just add it like that, k is a variable.
It would be like adding 3 + 3x and saying that's 6x.
Leave it in the expanded form, and then sub in your values of k, that should give you matching answers to the solution, or so I think, check it again I didn't write it out and try it.
Ok that makes sense but I run into problems when trying to find the negative values ie, I get
1*e^(n*pi)/12 for n=1,5,9... then I get 13,17,21 but the answer says -11,-7,-3... I can just work it out since I realized the roots are in = increments so i can subtract 4 from 1 then subtract 4 from -3 and so on...
but I was curious as to why I run into trouble here??
I'm not too sure what you're doing with the substitutions, but it might be your approach.
Backtrack a bit to where you calculated up to here:
Instead of doing what you did by adding it. Now substitute in values for k.
For e.g. k = 0, you will get \frac{\pi}{12}, if you take k = 3, you know that will go outside the bound of the principal argument, so you select k = 2, and you get \frac{9\pi}{12}
Compare these two to the answer, they match for n = 1, and n = 9 don't they?
Essentially, when you substitute a k-value your final answer becomes something of the form \frac{n\pi}{12}
For now, use the method you were doing earlier, substitute k-values get your 6 roots, and then you will see how the match up with \frac{n\pi}{12}, you will get the negative values by simply substituting negative k-values.
ok that was basically what I was doing it but I thought k was restricted to the positive integers.?
Why would k be restricted to positive integers only? Unless the question specifically asks for the roots when k is positive, but it doesn't.
The way someone showed me was that you add 2kpi to get more solutions where k=1,2,3...n-1.
By the way can you tell me if this is right??
Find all complex fourth roots of -1-i
so arctan(1)=pi/4 since its in the third quad then subtract pi so Arg(z)= -3pi/4
and |z|=sqrt(2)
so 2^1/8((cos((-3pi/4)+2kpi)+isin((-3pi/4)+2kpi))/n)
= 2^1/8 {(cos[-3pi+8kpi]+isin[-3pi+8kpi])/16} ----> for k =-1,0,1,2
=2^1/8 e^i(npi)/16 where n = -11,-3,5,13
Yes, those look correct, but beware of how you're expressing fractional exponents in polar form.
This is a bit hard to read, but...
That 16 should be included in the theta value for cos and sin.
cos(-3Pi/16) is not the same thing as cos(-3Pi)/16
Remember, you can always easily check your answers using online calculators.
http://www.wolframalpha.com/input/?i=roots+z^4+%3D+-1+-i
And yes, you add 2kPi to get more solutions as you've done here, but you can still use negative values of k, as that negative signs means you're going the other way.
Your error is multiplying the exponent for the sixth root by k. You need and additive term.
Since sine and cosine are periodic with period 2\pi, the exponential is periodic with period 2\pi i. So i= e^{(\pi/2+2k\pi)i} for any integer i.
From that, i^{1/6}= e^{(\pi/12+ k\pi/3)i}. k can be any integer but a given k and k+ 6 or k- 6 will give the same number so there are exactly 6 distinct sixth roots.
The only problem with wolfram is I can't really seem to get it in polar form so I can check my answers.
Although I just purchased maple so hopefully I will be able to work that out.
Is this answer for the original problem or the later posted??
It's for the original of course...he's talking about the 1/6 roots of i.
Getting some of the answers in a form you can understand in MAPLE can be a bit tricky.
Generally it's convert(%,polar) and evalc(%) that moves things around with Re(%) and Im(%)
Yeah ok thanks heaps for the help its great!
Start with an easier problem. Find the square root of i. Do it by drawing i on the complex plane and visualizing geometrically why the square root of i is what it is. Generalize.
I don't know if that's too vague but you should literally be able to do this problem in your head once you have the correct visualization.
  • · Replies 22 ·
  • · Replies 22 ·
