Finding the open ckt voltage (Thevenin equivalent problem)
12 replies · 2K views
rugerts
Find v_oc.
Mesh or Node analysis. => KVL and KCL.
I'm trying to find Vth (and then Rth). My work and results don't seem to agree with what my circuit simulation (done on LTSpice) shows. Can anyone point out what may be wrong here?
I didn't even try to follow what you did, since you did it the hard way. I suggest that you simplify the circuit (with the voltage source treated properly for getting Rth) and THEN do calculations.
This is what I'm going based off of.
What exactly are you talking about?
Also, is it really that hard? Granted, what you propose might be much easier, but what I'm doing isn't very involved.
Thanks for the reply.
You've got a circuit that easily resolves down to one resistor if you just simply properly. Don't even need to DO any loop or node stuff.
If you're new to all this, you'll soon realize that simplifying the circuit FIRST is almost always going to save time. On this problem, it totally SOLVES the problem (of getting Rth)
Could you be a bit more specific? You're saying it solves the problem, but how exactly? I've found Req to be 31.8473 k. It took a delta-wye transform.
No, just simple series & parallel 'til you get to a single R
Okay. Well that's one way of doing it. The delta wye works as well.
But, again, could you please follow up with what this would help with? If I'm interpreting you correctly, you're saying to find the single equivalent resistance of the entire ckt? Is this then equal to Rth? What about the voltage across the open ckt, Vth?
But messier by far
yes
What do you think?
Separate issue in either case.
In any case, whatever method you personally find easiest and fastest, that's what you should use. I think my way is that for Rth but maybe that's just me.
Also, you can use the same type of simplification technique to get Vth
Appreciate the feedback. I definitely think it's still important to solve the problem in different ways.
In the meantime, however, do you mind checking my work to see what may have gone wrong? It's bothering me quite a bit and I keep going over it, and can't seem to find what my mistake is.
I think you may have slipped up in your calculations here (finger error on your calculator?):
When I use your current values and resistance values in that calculation I get a ##V_{th}## of 11.32 V, agreeing with your spice simulation.
Yep. I get the same. Thanks for double checking.
