Finding the Range of $\frac{x-5}{x^{2}-9}$
  • Thread starter Thread starter BoundByAxioms
    Range
The discussion revolves around finding the range of the function \(\frac{x-5}{x^{2}-9}\). Participants explore various aspects of the function, including its asymptotic behavior and the implications of its numerator and denominator's degrees.
  • Participants discuss the implications of the degrees of the numerator and denominator on the range, questioning the presence of an asymptote at \(y=0\). Some suggest assuming the largest possible range and deriving a quadratic equation to analyze the function further. Others express uncertainty about specific values that may or may not be included in the range.
The discussion is active, with participants presenting different interpretations of the range and the behavior of the function. Some have offered guidance on analyzing the quadratic formed from the function, while others question the assumptions made about the range and the behavior near the asymptote.
There are ongoing debates about the function's behavior at specific points and the implications of horizontal asymptotes. Some participants are working under the assumption that the domain excludes certain values, which influences their conclusions about the range.
BoundByAxioms
[tex]\frac{x-5}{x^{2}-9}[/tex]
Usual range-finding methods. For this one, I thought that if the exponent of the numerator is smaller than that of the denominator, then there should be an asymptote at y=0, aka the range doesn't include 0. I think there is a special case for when the exponent on the numerator is exactly one greater than that of the denominator, but I'm not completely sure...
Already explained my reasoning. But, range should be y[tex]\neq[/tex]0.
Firstly, assume the largest possible range, R (any real number). Let R = (your expression). Bring the denominator over to R and you'll get a quadratic equation. Remember that you are assuming that the domain is any real number except +/-3. With that in mind, figure out what the quadratic expression must satisfy in order for the domain to be as assumed.
be as assumed.
Ok let's see:
R=[tex]\frac{x-5}{x^{2}-9}[/tex]. Then, R(x^{2}-9)=x-5. Then
Rx^{2}-x-9R+5=0. At this point I'm not sure what I'm doing, so I'll give
it a guess: Since x[tex]\neq[/tex]+/-3, I'll plug (-3) and (3) into x and
see what I get. (3R)^{2}-3-9R+5=0 which simplifies to 9R^{2}-9R=-2.
R^{2}-R+[tex]\frac{2}{9}[/tex]=0. Using the quadradic formula:
[tex]\frac{1 (+/-)\sqrt{(-1)^{2}-4(1)(\frac{-2}{9}} }{2}[/tex]. So it
looks like x=[tex]\frac{1}{2}[/tex] +/- [tex]\frac{1}{3}[/tex], so
x=[tex]\frac{5}{6}[/tex] and x=[tex]\frac{1}{6}[/tex]. So the range can't
include those two values? By the graph it looks like the range doesn't
include anything between those two values. And why isn't there an
asymptote at y=0?
Bumping thread since I need to know the answer also.
BoundByAxioms said:
And why isn't there an asymptote at y=0?
There is an asymptote at the x-axis, but as [tex]x\rightarrow\infty[/tex] : [tex]y\rightarrow0^{+}[/tex].
The function crosses from the negative values into the positive (thus intersecting the x-axis at x=3) but then treats y=0 as an asymptote from there on.
I am also curious for the answer here.
The range certainly does include 0. It should be obvious that y(5)= (5-5)/(25-9)= 0.
y= (x-5)/[(x-3)(x+ 3)]. There are vertical asymptotes at x= 3 and -3. For x< -3, all three factors are negative so y is always negative. The graph approaches y= 0 from below as x goes to -infinity, then goes down to -infinity as x approaches 3 from below. y is very large for x slightly larger than -3, reaches a local minimum at about x= -1, then goes to infinity as x goes to 3 from below. For x slightly greater than 3, y is a large negative number, crosses the x-axis at x= 5, reaches a local maximum at about x= 11 then decreases toward 0 as x goes to infinity.
The range is all real numbers, including 0.
Hi Halls,
I'm not seeing why the range is all real numbers. I tried out what I suggested earlier and I determined the range of values to be either <0.0574 or >0.387. Which means values like 0.1 isn't found in the range. If we consider x to be restricted to the reals (I assume it is), then there isn't any real number x such that the expression = 0.1.
Take a look at the graph and you'll see that not all real numbers are within its range.
What I've been told is that there is always an asymptote at y=0 whenever you have something like f(x)=[tex]\frac{x^{a}}{x^{b}}[/tex] where a<b. When is that true? Because clearly it's not true for this particular function.
Defennder said:
Hi Halls,
Yes, you are right! I didn't look at it closely enough before- there a small horizontal lane the graph does not go into- very difficult to get any specific values but differentiating and finding the local max and min should do it.
That certainly is true of this function. What you were probably NOT told is that a graph can't cross a horizontal asymptotote.
Important point: "there should be an asymptote at y=0, aka the range doesn't include 0" is WRONG. Saying y= a is a horizontal asymptote only tells you that the graph approaches y= a as x goes to infinity or negative infinity. It does NOT tell you anything about what happens for other values of x. In particular it does not tell you that the graph does not cross y= a.
Graph y= x/(x2+ 1). That's a continuous function that has y= 0 as a horizontal asymptote but is 0 for x= 0.
If [tex]t[/tex] is a real number in the range of this function, then
[tex] t = \frac{x-5}{x^2-9}[/tex]
To find the set of numbers that can be used for [tex]t[/tex]
[tex] \begin{align*}<br /> t (x^2 - 9) & = x-5 \\<br /> tx^2 - 9t - x + 5 & = 0\\<br /> tx^2 - x + (5-9t) & = 0<br /> \end{align*}[/tex]
If the determinant of the final quadratic is negative there are no solutions for [tex]x[/tex]. Since the determinant will depend on [tex]t[/tex], we can find the values that are not in the range.
[tex] \begin{align*}<br /> D(t) & = (-1)^2 - 4(t)(5-9t) \\<br /> & = 1 - 20t + 36t^2<br /> \end{align*}[/tex]
The zeros of the quadratic in [tex]t[/tex] are [tex]{36}/{72} = 1/2[/tex] and [tex]4/{72} = 1/{18}[/tex]. Since the graph of [tex]D(t)[/tex] is a parabola that opens upward, the vertex is the minimum point.
[tex] \begin{align*}<br /> t & = \frac{-(-20)}{72} = \frac{20}{72} = \frac 5{18}\\<br /> D(5/{18}) & \approx -1.8<br /> \end{align*}[/tex]
Since [tex]D(t)[/tex] is negative at the vertex, it is negative throughout the interval
[tex] \left(\frac{4}{72}, \frac 1 2 \right)[/tex]
The range consists of all real numbers except for those in this interval
Well done, statdad, though not necessary to post it twice!:smile:. Oh, and the word you want is "discriminant", not "determinant".
Statdad replies (as he hangs his head in shame)
I know it should be discriminant - teach the stuff almost every semester. No excuse there - just an incredibly big brain lapse and failure of proof-reading.
Posting twice I can explain: the first time I tried I got the infamous "data base error" and some message telling me the item hadn't parsed. I went back to the edit screen and hit submit once again. I didn't notice that both versions posted. Sorry.
(wanders away with hanged head, chastened look upon face)
  • · Replies 23 ·
