Finding the range of rational functions algebraically
The discussion focuses on finding the range of the rational function f(x) = 1/(x² - 4) algebraically. Participants conclude that the range is divided into two intervals: (-∞, -1/4) and (0, +∞). They derive this by solving the inequality 1 + 4R > 0, which leads to the conclusion that R must be greater than -1/4 and not equal to 0. The conversation emphasizes the relationship between the function's critical points and its range, specifically noting that there is no minimum value for this function.
  • Understanding of rational functions and their properties
  • Familiarity with algebraic manipulation and inequalities
  • Basic knowledge of limits and critical points in calculus
  • Ability to differentiate functions to find maxima and minima
  • Study the algebraic methods for finding the range of rational functions
  • Learn about critical points and their significance in determining function behavior
  • Explore the concept of inverse functions and their relationship to range and domain
  • Investigate the use of limits in analyzing the behavior of rational functions
Mathematics students, educators, and anyone interested in mastering the analysis of rational functions and their ranges.
vrmuth
how to find the range of rational functions like f(x) = \frac{1}{{x}^{2}-4} algebraically , i graphed it and seen that (-1/4,0] can not be in range . generally i am interested in how to find the range of functions and rational functions in particular
Mathematics news on Phys.org
How do you think it might relate to the maxima and minima of the function? Where are those for your example?
yes i got those points by differentiating but can't we find it without using derivatives ? i mean any algebraic method ?
I can't think of any algebraic methods, and if I were to use logical reasoning, it would still involve some kind of crude link to limits and derivatives.
By inspection |x| = 2 is critical and x = 0 is a local minimum.
minimum ? it's max. there is no minmimum for this function .but how can i find the range though ? i mean how it's useful to find out the range exactly ?
You're right. It is local max (-1/4). As |x| -> 2 from below, f(x) -> -∞. However |x| -> 2 from above, f -> +∞. Finally as |x| -> ∞, f -> 0.
Net result: range has two parts (-∞,-1/4) for |x| < 2, and (0,+∞) for |x| > 2.
I took a little while to think about it, and yes, there is an algebraic solution to the problem.
For the function
y=\frac{1}{x^2-4}
let the range be denoted R, which is also the y-value, so we have
R=\frac{1}{x^2-4}
Now, we want to solve for x:
Rx^2-4R=1
x^2=\frac{1+4R}{R}
x=\pm\sqrt{\frac{1+4R}{R}}
Now, x exists (and thus a correspondent range exist) whenever
\frac{1+4R}{R}\geq 0
and clearly the opposite of that is, if
\frac{1+4R}{R}&lt; 0
then the domain does not exist, thus the range does not exist.
Now, if we solve this inequality, for R>0 (we can see that R\neq 0)
1+4R&lt;0
R&lt;\frac{-1}{4}
And we obviously can't have that both R>0 and R&lt;\frac{-1}{4} so we scrap that. Now if R<0
1+4R&gt;0
R&gt;\frac{-1}{4}
Which gives us the intersection \frac{-1}{4}&lt;R&lt;0 as required.
For the function
y=\frac{1}{x^2-4}
R=\frac{1}{x^2-4}
Rx^2-4R=1
x^2=\frac{1+4R}{R}
1+4R&lt;0
R&lt;\frac{-1}{4}
1+4R&gt;0
R&gt;\frac{-1}{4}
There are no values of x where -1/4 < y < 0. As I have indicated, the range is everything but this interval.
\frac{1+4R}{R}&lt; 0.
For the function
y=\frac{1}{x^2-4}
R=\frac{1}{x^2-4}
Rx^2-4R=1
x^2=\frac{1+4R}{R}
1+4R&lt;0
R&lt;\frac{-1}{4}
1+4R&gt;0
R&gt;\frac{-1}{4}
can u please explain to me how did u reach the conclusion that R will be greater than zero? solving the inequality only yields R>-1/4
I had written that precisely a year ago :biggrin:
Since -1/4 &lt; R &lt; 0 is where the range of the function does not exist, everything else is where the range does exist.
So the range is
y&gt; 0 \cup y\leq -1/4
(edit: y\neq 0 because we can't divide by 0)
If there's something in my earlier solution that you don't understand, just point it out.
lol well I'm glad u're still alive :P, yes there is something i do not get, the range of that function would be the domain of the inverse function correct? 1+4R/R > or equal to 0 will give us all the possible range correct?
solving this only gives us range bigger than -1/4, and range does not equal to 0, but as u already know this function has range above than zero, the question is how did u deduce that from the problem/inequality?
Yes and yes.
Oh you're right about excluding R=0 from the solution, I missed that. You're not solving the inequality correctly though.
Remember that when you multiply through by R, if R<0 then you need to change the reverse the sign of the inequality
So for R>0
1+4R\geq 0
but for R<0
1+4R\leq 0
Now when you solve these two inequalities, you only keep the intersections that makes sense. For example, if we assume R<0 but then solve the inequality and find that R>1, there are no solutions for R such that both of these can hold true at the same time (we say that the intersection of the sets is the empty set). If however we assume R<0 and solve the inequality to find R>-1, then our solution set is -1<R<0.
