Finding the value for rejection region using some kind of table
  • Level: Undergrad
  • Thread starter Thread starter korr2221
    Table Value
1 reply · 11K views
korr2221
I'm lost no how to find the cutoff rejection region and which table to use?
This is an example,
Data
n 34
X-bar 10.3
s 3.1
98% Confidence Interval for µ is
10.3 ± 2.33 x 0.5316
= (9.0632 , 11.5368)
Hypothesis
H0: µ ≤ 9
H1: µ > 9
Tests Z-stat = 1.3 = 2.4452
Statistic 0.5316
Significance Level = 0.01
Rejection Region =
Tail = RIGHT
Cutt -Off = Z-alpha = 2.326
Decision = Reject H0
p-value = 0.0072
I understand how they reject H0, but I am lost how they got 2.326. I think it's in the Z-table but I'm not sure, can someone explain to me clearly. It would also help if you can tell me how to find 0.0072 for the p-value.
I'm not sure how your Z table is set up - whether it gives only tail areas or cumulative probabilities.
If it gives tail areas (areas to the right of specific Z-values, do this: look through the AREAS for 0.01 - the associated Z-value will be 2.326
If your Z- table gives cumulative probabilities (areas of the form P(Z <=z)), look for the area that is closest to 0.99 (this is 1 - 0.01) - again, the Z-value should be 2.236.
Some tables only give the area between 0 and specified values of Z. If this is the case, look through the areas for the value closest to 0.49 - again, you should find Z = 2.236.
