Finding the Velocity of a Projectile knowing only Launch Angle and Flight Time
The discussion revolves around determining the velocity of a projectile given its launch angle, flight time, and some additional parameters. The subject area is projectile motion, focusing on the relationships between time, angle, and velocity without complete information on distance or horizontal velocity.
  • Participants explore the implications of the flight time of 4 seconds and question the relevance of the "horizontal length" mentioned. There are attempts to clarify what is meant by horizontal length and its significance in the context of the problem.
The discussion is ongoing, with participants providing hints and asking for clarification on the problem statement. Some guidance has been offered regarding the vertical component of motion and the factors that determine time in the air, but no consensus has been reached on the interpretation of the parameters provided.
There is confusion regarding the term "horizontal length" and its relevance to the problem. Participants express a need for the full problem statement to better understand the context and requirements. The discussion also highlights the importance of distinguishing between launch parameters and other factors.
flyparnape
Quick question, how would I find the velocity of Projectile Motion without knowing the total distance
I'm given the object mass: 13.874g, Angle of Launch: 40˚, the horizontal length of 60cm and the time it lands on the ground: 4s. Also, gravity is obviously 9.8m/s
I don't know the distance or the horizontal velocity so I can't find any logical solution
The fact that the projectile was in the air for ##4s## must tell you something.
What does "horizontal length" mean?
Hint: Consider the vertical component of motion.
So horizontal length is the length of the object when placed at the angle of launch. Am I supposed to find the distance from the ground
Where did the horizontal length come from? Is that mentioned in the problem statement?
The horizontal length comes from the position of the rocket before launch
Not sure how that is relevant. Could you please post the full problem statement so we can see what's being asked for in context?
Yes, the POSITION of the rocket, not the length of the rocket.
flyparnape said:
Also, gravity is obviously 9.8m/s^2
(fixed your units for you) :smile:
flyparnape said:
Homework Statement:: Quick question, how would I find the velocity of Projectile Motion without knowing the total distance
Relevant Equations:: I'm given the object mass: 13.874g, Angle of Launch: 40˚, the horizontal length of 60cm and the time it lands on the ground: 4s. Also, gravity is obviously 9.8m/s
What aspect of the launch parameters determines the time in the air (for a flight that starts and finishes at the same height)?
horizontal length, and gravity
I don't think that's the answer we were expecting. Normally, in projectile motion problems the horizontal length of an object is not relevant. In any case, the length of an object tells you nothing about launch speed and angle.
There a hint there about the correct answer.
Please post the full problem statement. That way we'll know exactly what you're given and what you're asked to find.
I sense a language issue. By "horizontal length", do you mean how far the projectile moves horizontally between its launch and when it lands?
Here's is a picture of the object
Interesting. Now (as previously advised) see if you can use the given information (that 4s, for instance) to figure out the vertical component of the initial velocity.
So, not actually a rocket. That takes care of one pointless mystery. Another two or three pages and we might actually figure out what the homework problem is.
  • Haha
If you are trying to determine the initial velocity of the projectile from the time of flight, then you should shoot it straight up in the air, i.e. make the "known angle" 90o.
Neither of those are "launch parameters".
When you set up to launch an object on some trajectory, what aspects do you control?
If your objective is just to calculate the initial velocity, you have all the information you need. (And some that you don't!)
You control the angle of launch
And the speed.
Or to look at it another way, the parameters are the horizontal speed and the vertical speed.
Of those four, is there just one that determines the time in the air, assuming the landing height is the same as the launch height?
  • · Replies 38 ·
  • · Replies 36 ·
27K
  • · Replies 21 ·
