Finding Time For Projectile Motion
3 replies · 3K views
phhysicssai
A marble launcher shoots a marble with a launch velocity of 6.89 m/s @15.0 degrees above horizontal.
-Find the marble's range.
(I tried to do this but I need to be able to find the time for horizontal motion... how would I do that?)
The time is calculated by considering the vertical component of the motion, and treating it like any other vertical motion example.
Or you could have a read of the
http://en.wikipedia.org/wiki/Range_of_a_projectile
then you only need a substitution - provided your projectile is landing at the same level it was launched from and not from/onto a hill/cliff/building.
Because its 6.89m/s @ 15.0deg, you can use trigonometric functions to find the initial vertical and horizontal speed:
vertical:
sin(15.0) = o / 6.89
horizontal:
cos(15.0) = a / 6.89
Since the horizontal velocity is constant as gravity does not affect it, the time the projectile is in the air can be found by:
v = a*t
where
v = vertical
a = acceleration due to gravity
t = time of projectile
Once you have the time of the projectile its simple.
We know that distance = velocity * time
-> d = v * t
where d is the "range" we are trying to solve for
where v is the HORIZONTAL velocity
where t is the time of the projectile
Once you have done this, post your work/solution so I can help you further. Nobody here is going to do you homework for you, we can only HELP you if you are trying.
jack343, you are forgetting that the projectile goes up AND down so the time of flight is double what you calculate.
