Wumbolog
- 13
- 0
A fkdkdkel
The discussion revolves around a problem involving a 4 kg object moving in two dimensions, with a focus on its velocity and the effects of a constant force. Participants are examining the relationship between acceleration, velocity, and force in the context of the problem.
The conversation is ongoing, with some participants expressing confusion about the problem's formulation. There is a recognition of the need for clearer definitions and assumptions, particularly regarding the direction of the force and the correct use of terms related to motion.
Participants note that the problem's wording may lead to misunderstandings, particularly in mixing terms related to acceleration and velocity. The original poster acknowledges the confusion and attempts to clarify their intent.
Travelling at 40m/s, right?Wumbolog said:A 4kg object traveling at 40m/s^2
Which direction does the force act?along the x-axis at t=1 is influenced by a constant force of 20N.
haruspex said:Travelling at 40m/s, right?
SteamKing said:The OP says the 4 kg object is traveling at 40 m/s^2. Usually, the velocity of an object is given, not its acceleration. Is this how the problem was originally specified? 'Traveling' implies velocity, otherwise, one would say an object is accelerating at X m/s^2.
In specifying a problem, you can't mix cause and affect like this. You can either state the acceleration (and ask for something which can be deduced from that, like position, velocity..) or you can specify forces and let the acceleration be deduced.Wumbolog said:Yes, I meant accelerating, I apologize. I "made" this problem to see what I could do given the acceleration
