Finding voltage at a specific time in AC waveform with phase shift
  • Thread starter Thread starter newbie991
    Ac Waveform
12 replies · 5K views · last reply
newbie991
v = 60sin(458t + 60º)
Find the voltage of the waveform when t = 5ms
It may be a silly question but I've just started studying ac, just wondering how that + 60º affects the equation?
any help would be appreciated as I've looked everywhere for the method...
V = VmSin(2πft)
=> v=60sin(458(5x10-3) + 60º)
=> v=60(0.039957 + sin60º) ? -----> not sure if this is correct
I would appreciate any reply :smile:
~Newbie
Welcome to PF, newbie991!
The 60º only sifts the angle, well 60 degrees. You've probably done trigonometry, where sin(∏+∏)=sin(2∏). You just got to be careful, though. Here the voltage is in the form v=60sin(ωt+60º).
Thanks, very interesting forum indeed! :)
Thanks for the reply, I've roughly plotted out this function and I am getting a different answer to the theoretical value.
what would you estimate it to be?
from the forumula I've extracted:
vmax=60 p-p = 120
f=72.892Hz
T=13.71ms
assuming all that is correct, i found v after 5ms to be between -40 and -20, although I am getting -11.66.
60 Sin (458 (5x10-3) + 1/3 ∏) = -11.66
I know there's something right in front of me I am not seeing!
would appreciate any further help!
~Newbie
newbie991 said:
vmax=60 p-p = 120
I'm not quite following you here. What does the last part, p-p = 120, mean?
When I graphically checked the answer, I got the same as plugging in the values to the given signal.
ah sorry that's kind of irrelevant that's the peak to peak voltage,
could you tell me what your answer was so i can see if I am on the right track?
or could you tell me where I am going wrong here:
The way the problem was originally listed, it looks to all be in degrees. You just made an error with your calculator in multiplying 5ms * 458:
Re-check 458 * 0.005 = ______
__________________
thanks for the reply :smile:
458 * 0.005 = 2.29 :-p
ok this is exactly what I am entering:
rad mode:
60 sin (458(0.005) + 1/3 ∏)
and I am getting: -11.66159...
rad mode:
sin(458 * 0.005) = 0.752
sin(PI/3) = 0.866
sin(458 * 0.005 + PI/3) = sin(2.29 + 1.047) = sin(3.337) = sin(3.337 - 3.142) = sin(0.195)
So the answer cannot be negative. Try doing the calculation in a different order, and also do the individual pieces to check your work.
sin(PI/3) = 0.866
Oops, my bad. I subtracted only one PI inside the sine... that's not right. Give me a sec...
sin(3.337) = -0.194
60 * sin(3.337) = -11.65
Are you sure that's not the right answer? If it's not, then maybe the whole original problem was in degrees after all.
Is the answer 60sin(2.29 + 60) = 53.1 ?
I get the same V=-11.66V as well. Is this an online assignment, or how do you know it's not the right answer?
If the problem was in degrees, I would assume the angular frequency would have the degree symbol added. After all, rad/s is the more commonly used unit.
that is the correct answer :wink:
went over everything again and -11.66 is correct :biggrin:
was just a silly mistake on my part!
thanks a lot for your help Kruum and berkeman, much appreciated :wink:
