Finding Volume of Rotated Solid: Disk Method
The discussion revolves around finding the volume of a solid obtained by rotating a region bounded by the curves y=5e^-x, y=5, and x=4 about the line y=10 using the disk method.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to visualize the problem and is uncertain about determining the radius for the disk method. Some participants suggest drawing lines to find the radius and setting up the integral. There are also discussions about the setup of the integral and algebraic manipulation involved in calculating the volume.
Participants are actively engaging with the problem, providing suggestions and corrections. There is a mix of attempts to set up the integral and concerns about algebraic errors affecting the final answer. While some guidance has been offered, there is no explicit consensus on the correct approach or solution yet.
The original poster mentions that the homework is mandatory and conducted through an online platform, which adds pressure to ensure the correctness of the final answer. There are no textbook problems assigned this semester, which may influence the discussion dynamics.
xibalba1
Consider the solid obtained by rotating the region bounded by the given curves about y=10
Find the volume V of this solid using DISK METHOD
y=5e^-x, y=5, x=4
setting up the picture easy. but I'm having trouble knowing HOW to find the radius. any help would be cool. thank you.
draw a horizontal line from y=10, then draw a vertical line down & see where it intersects the region, the radius is the vertical disatnce from y=10 to the point in your region
from that you should find an innner (ri) & outer (r0) radius, that may be both be functions of x.
then set up the integral over x
corrected above after drawing it
Okay, I think I know what you are saying. so far I got pitimes the integral from 0 to 4 of [(10-5e^(-x)]^2 -(5)^2 dx
what do you think
what do you think
Yep, that's it!
Dude man, I keep getting the wrong answer, or at least www.webassign.net tells me so. SO...the problem must lie within my algebra.
I freaking hate webassign.net. You do all this work by setting up the problem, doing the calculus, etc, but it aint worth crap because you get the final answer incorrect. B.S. man, you know what I mean?
By the way, www.webassign.net is my MANDATORY online homework I have to do. No TEXT BOOK problems were assigned this semester. They're all on webassign. Argh.
[tex]V = \pi \int_0^4 \left[ (100 - 100e^{-x} + 25e^{-2x}) - 25 \right] dx[/tex]
[tex]= \pi \int_0^4 25e^{-x}(e^{-x} - 4)dx \ + \ 75\pi x|_0^4[/tex]
Let [tex]u = e^{-x} - 4 \ \Rightarrow \ du = -e^{-x}dx.[/tex]
So [tex]V = 300\pi - 25 \pi \int u du[/tex]
[tex]= 300\pi - 25 \pi \left( \frac{(e^{-x} - 4)^2}{2} \right) \right|_0^4.[/tex]
Does that help?
  • · Replies 16 ·
