Finding x and its error from values satisfying c ≤ δc
16 replies · 2K views
Arman777
Insights Author
Let us suppose we have one constant variable ##b \pm \delta b = 20 \pm 1 ## and one function that depends on ##x ##, such as, ##a(x) \pm \delta a ##
The problem is I want the difference between ##a(x) ## and ##b ## to be ##0 ##. Let me denote this difference as ##c \pm \delta c ##. To obtain a difference which is ##0 ##, we can have only one condition ##c \leq \delta c ##.
We are also given a range of ##x ## values.
So the problem is something like this.
Take a range of ##x ## values (such as ##{0,2} ##)
For each value of ##x ## in this range;
1) Calculate ##a(x) \pm \delta a ##
2) Take the difference between ##a(x) ## and ##b ##;
##c \pm \delta c = (a(x) \pm \delta a) - (b \pm \delta b) ##
3) if ##c \leq \delta c ## (if the difference can be ##0 ##), add it to an array that stores the values of the ##x ##.
Now after this we have some values of ##x ## that satisfy ##c \leq \delta c ##. How can you find ##x ## and ##\delta x ## from this array
Some caveats are in order:
1) You want to be sure ##\Delta a## and ##\Delta b## are uncorrelated
2) You mean ##\ | c | \leq \Delta c\ ## of course.
And the 'for each ##x##' can lead to a wrong result. Numerical example:
a = 400 ± 40, b = 360 ± 20, so c = 40 ± 45
And let a = 200 x ##\Rightarrow ## x = 2.0 ± 0.2
Your array of x is, for example, 1.78, 1.79, ... 2.22.
Then the average is 2.0 and the standard deviation 0.13
Reason: your ##x## has a flat distribution instead of a normal distribution##\ ##
BvU said:
1) You want to be sure Δa and Δb are uncorrelated
2) You mean |c|≤Δc of course.
Yes
BvU said:
Reason: your x has a flat distribution instead of a normal distribution
Yes I have noticed that...that seems like a trouble
BvU said:
And the 'for each x' can lead to a wrong result. Numerical example:
And let a = 200 x ⇒ x = 2.0 ± 0.2
I mean a different way actually. Think like this,
You have a some range of ##x## values from ##0## to ##2##. Then you are doing a loop such that
for each value of ##x##:
$c \pm \delta c = (a(x) \pm \delta a) - (b \pm \delta b)$
if $|c|≤Δc$:
add x to an array
Arman777 said:
I have revised the problem
Makes my reply quasi-incomprehensible :cry: !
Even so: some more editing is in order :wink:
Waiting
Waiting for ? Ah - ##\TeX## details adjusted.
That doesn't tell us what the probability distribution of ##x## is going to be.
Please don't do that. Because...
sorry about that
Well I have printed the values and they were normally distributed
So how can that be ? Pure luck, or something else, like the dependency of ##a## on ##x## ?
Or some monte carlo principle ?
Its actually has the similar idea as your. The relationship between ##x## and ##a## is linear. So as we increase ##x## at some point it hits ##-\delta c## and another point it hits ##+\delta c##. The problem how can I calculate ##x## and ##\delta x## from the given data list.
This is the histpgram of the ##x## values.
Looks pretty uniform to me :smile:
So mean(x_values) and std(x_values) are the correct solution ?
According to the numerical example, mean would be ok, st dev would be too optimistic
Yes, I know. In the example I started with 2##\pm##0.2. The flat distribution gave a sigma of 0.13, about a factor of ##\sqrt 3## lower. Your procedure cuts at ##\pm\sigma## -- whereas a gauss distribution has , what was it again, 68% within ##\pm\sigma## and the remainder outside, contributing happily to the standard deviation.
