Finding y = 2.3×10⁵ + 6.1×10⁶ + 3.2×10⁷ without a calculator
  • Thread starter Thread starter MatheusMkalo
    Numeric Value
4 replies · 2K views
MatheusMkalo
Numeric value of y.
y = 2.3*105+6.1*106+3.2*107
Without calculator, how? '-'
Er, what exactly are you having trouble with? (e.g. do you know how to compute [itex]10^5[/itex]?)
If i compute 105 and others:
32000000+6100000+230000 = 38330000
But if i have 50 questions like that and 1 hour to do all the questions? '-'
Don't have a easy way?
Sorry, my english is bad.
Such a test would still give you over an entire minute per problem!
If it takes you more than a minute to do a problem like this, (even without any shortcuts!) then you just need to practice.
I fully believe if you do a dozen or so practice problems, you'll start to see some short-cuts of your own -- e.g. shorthand for some parts of the numeral, or some parts of the answer you can just write down without having to do any computation at all.
I suspect these short-cuts are probably better figured out on your own than taught. e.g. I could tell you that you didn't really need to write down the last 4 0's of each number in your scratch work, but I doubt me telling you would have the same impact as you figuring a short-cut out yourself after working through enough exercises. It's almost always easier to use your own short-cut than somebody else's short-cut. (even if they are essentially the same thing)
MatheusMkalo said:
Numeric value of y.
This can be an exercise in managing zeros:
2.3 * 10^5 = 2.3 * 10^5
6.1 * 10^6 = 61. * 10^5
3.2 * 10^7 = 320. * 10^5
Sum = 383.3 * 10^5 = 3.833 * 10^7
