Finding Y Component for Vector Field F with Zero Divergence
stunner5000pt
Suppose we have the vector field F whose x component is given by [itex]F_{x}=Ax[/itex] and whose divergence is known to be zero [itex]\vec{\nabla}\cdot\vec{F}=0[/itex], then find a possible y component for this field. How many y components are possible?
2. The attempt at a solution
So the divergence in cartesian coordinates is given by
[tex]\frac{\partial F}{\partial x}+\frac{\partial F}{\partial y} = 0[/tex]
Using the fact that [tex]F_{x}=Ax[/tex]
[tex]A+\frac{\partial F}{\partial y} = 0[/tex]
[tex]\frac{\partial F}{\partial y} = -A[/tex]
integrate both sides with respect to y we get
[tex]F_{y}=-Ay+B[/tex]
where B is a constant
is that sufficient for a possible y component? For the question with howm any are possible... arent there infinite possibilities since B could be anything. But they are all parallel to each... linearly dependent on the above answer?
As far as I'm concerned, you're good to go.
but.. infinitely many solutions because of B or finite because they are all linearly dependent on the solution given?
There is an infinite amount of parallel solutions.
