Finite Fields and ring homomorphisms HELP
The discussion revolves around proving that the kernel of the ring homomorphism from Z to F, defined by n mapping to n * 1F, is of the form pZ for some prime p. It is established that the kernel consists of integers a such that f(a) = 0, leading to the conclusion that only multiples of a prime can map to zero in a field. The participants clarify that since F is a field, the kernel must be a prime ideal, which aligns with the structure of ideals in Z. The discussion emphasizes that if the kernel is mZ, where m is composite, it contradicts the properties of the field F. Ultimately, the conversation aims to demonstrate that F is a finite-dimensional vector space over Z/pZ, resulting in F having exactly p^d elements.
cheeee
Assuming the mapping Z --> F defined by n --> n * 1F = 1F + ... + 1F (n times) is a ring homomorphism, show that its kernel is of the form pZ, for some prime number p. Therefore infer that F contains a copy of the finite field Z/pZ.
Also prove now that F is a finite dim vector space over Z/pZ; if this dim. is denoted d, then show that F has exactly p^d elements.
I know that the kernel of a ring homomorphism is defined as ker(f) = {a in Z : f(a) = 0}
but I am still having trouble exactly where to go from this...it appears that the only element of Z s.t. f(a) = 0, is 0 which would map to 0 * 1F = 0. But how is this of the form pZ, for some prime p??
Any help or push in the right direction would be great...thanks.
If R and S are rings, the kernel of a ring homomorphism \phi: R \to S is an ideal of R. What are the ideals of \mathbb{Z}?
Of those ideals, only some of them can be the kernel of a homomorphism \mu: \mathbb{Z} \to F given by \mu(n) = n \cdot 1_F. The others are incompatible with one of your hypotheses.
Okay I get that the all of the ideals of Z are of the form mZ for some integer m, but I am still not sure how n*1F implies that the kernel must be a prime ideal of Z?
The important thing here is that F is a field (or at least an integral domain). If the kernel of \mu is (m) = m\mathbb{Z}, and m = rs is composite, think about the equation \mu(m) = \mu(r)\mu(s).
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
