How to Solve a First-Order Nonlinear PDE using the Method of Characteristics?
To solve the first-order nonlinear PDE du/dx * du/dy = x*y with the initial condition u(x,y) = x for y = 0, the equation can be expressed in the form F(x,y,u,du/dx,du/dy) = 0. By assuming a separable solution u(x,y) = A(x)*B(y), the PDE can be transformed into two ordinary differential equations. The solutions to these ODEs yield a particular solution of the form u(x,y) = x*(y^2 + 1)^(1/2). The method of characteristics is confirmed to be the appropriate approach for solving this problem, leading to the same result. The final solution is u(x,y) = x*(y^2 + 1)^(1/2).
Eren10
i have to solve this equation :
du/dx * du/dy = x*y
u(x,y) = x for y =0
with putting this equation in the form : F(x,y,u,du/dx,du/dy) = 0 . it can be solved.
But mine book does not explain how to do this, there are no examples.
Can someone help me ? or any links of examples on the internet?
Your PDE already is in a such form!?
If you suppose that
u(x,y)=A(x)*B(y)
then substitution such u into PDE gives you after separation of variables
diff(A(x),x)*A(x)/x=1/(B(y)*diff(B(y),y)/y)=c ,
where c is a constant. Solutions of these two ODEs lead to particular solution
u(x,y) = (c*x^2+C2)^(1/2)*1/c*(c*(y^2+C1*c))^(1/2)
(among other things this solution allows to obtain the general sulution to your PDE!).
If now substitute y=0 into above solution, we find that it must be
C2=0, C1=1/c
so the required solution is as follows
u(x,y) = x*(y^2+1)^(1/2)
Thank you for giving the answer. Mine mistake I had to tell, to solve this problem we had to use method of characteristics. I did it and found the same answer. so it is correct.
  • · Replies 36 ·
