First order ODE, orthogonal trajectories
The discussion focuses on solving first-order ordinary differential equations (ODEs) related to orthogonal trajectories of ellipses defined by the equation ##\frac{x^{2}}{k^{2}} + \frac{y^{2}}{\frac{k^{4}}{4}} = 1##. The correct derivative is established as ##\frac{dy}{dx} = \frac{-x}{4y}## for the ellipse, while the orthogonal trajectories are derived from the equation ##\frac{dy}{dx} = \frac{4y}{x}##, leading to the solution ##y = Cx^{4}##. The discussion also addresses concerns about potential loss of solutions at points where x or y equals zero, confirming that these solutions remain valid.
  • Understanding of first-order ordinary differential equations (ODEs)
  • Familiarity with implicit differentiation
  • Knowledge of ellipses and their properties
  • Ability to solve differential equations analytically
  • Study the derivation of orthogonal trajectories in differential equations
  • Learn about the properties of ellipses and their tangents
  • Explore the method of separation of variables in ODEs
  • Investigate graphical representations of families of curves
Mathematicians, physics students, and anyone interested in advanced calculus, particularly those studying differential equations and their applications in geometry.
Panphobia
1. The problem statement, all variables and given/known da
##\frac{x^{2}}{k^{2}} + \frac{y^{2}}{\frac{k^{4}}{4}} = 1## with k != 0
this can be simplified to
##x^{2} + 4y^{2} = k^{2}##
Find dy/dx implicitly, then find the new dy/dx if you want orthogonal trajectories to the ellipse. Lastly solve the differential equation and ifentify the orthogonal trajectories on the ellipse.
##2x + 8y\frac{dy}{dx} = 0##
now I know that for it to be orthogonal you need -dx/dy, so rearranging for dy/dx would give
## \frac{dy}{dx} = \frac{-x}{4y} ##
and -dx/dy is
## \frac{-dx}{dy} = \frac{4y}{x} ##
but my question is wouldn't you be losing solutions for y=0 and x=0? How would you account for that in the solution?
You are not necessarily losing those solutions. They are still there. For example, if ##-\frac{dx}{dy} = \frac{4y}{x}##, then what does that mean when x = 0? Normally an ellipse (centered at the origin) might have a vertical tangent line as it crosses the x axis, how is that slope represented? What is perpendicular to that?
Yea I get what you mean, I solved the differential equation and got ## y = Cx^{4} ## and one of the questions is to draw four members of each family of curves, so it should be pretty simple with the ellipse, but then with the ## y = Cx^{4} ##, is it still possible for me to draw the solution through x=0?
An obvious point is that taking C= 0 gives y= 0 as a solution- a horizontal line through (0, 0).
and -dx/dy is
You have the wrong differential equation: the solutions of ##2x + 8y\frac{dy}{dx} = 0## just give you the ellipse itself, because when ##2x dx + 8y dy = 0## that means that the points ##(x,y)## and ##(x + dx, y + dy)## lie in the ellipse; in other words, ##(dx,dy)## lies in the tangent line to the ellipse.
You want your ##(dx,dy)## to be perpendicular to the tangent, not parallel to it. Thus, you want ##(dx,dy)## to point along the gradient of the function ##f = x^2 + 4 y^2##. Thus, you need
## dx = 2x \, dt, \;\; dy = 8y \, dt ##, so ##dy/dx = 4y/x.##
I did solve the differential equation for ## dy/dx = 4y/x ## it is ## y = Cx^{4} ##
Nowhere in your writeup in post #1 did you write that DE and that solution. I looked and looked, but could not find it.
